Twin turbo HELP!! 66 442
Old January 2nd, 2016, 04:57 PM
TT66olds442's Avatar
I'm looking to add a twin turbo with intercooler setup to my 1966 Oldsmobile 442. I've never built a turbo motor so I was wondering if someone can let me know what I will need. Thanks in advance.
TT66olds442 is offline
Old January 2nd, 2016, 07:11 PM
Welcome to the site, I moved your thread to the performance section. Hopefully you'll get some suggestions soon.
oldcutlass is offline
Old January 2nd, 2016, 07:35 PM
Octania's Avatar
Well, you would need a pair of turbos, first.
I can't be much help beyond that. I know forced air induction motors usually use lower compression pistons, so... what was your budget again?
A normal engine costs like $5k+ so you are looking at 20k maybe?
Octania is offline
Old January 3rd, 2016, 07:14 PM
Well I got a pair of t3/t4 turbos with an intercooler......looking for manifolds and I'm looking at a blow through carb from demon. Don't know what else I would need as far as heads, cams and the bottom end. Not looking to race it, just always wanted to have a turbo car. Maybe someone can post some links to sites where I can find the parts. I've been having problems finding the mainifolds for it.....
Old January 3rd, 2016, 07:24 PM
oldsfromyell's Avatar
You will have to make your own manifolds or try to adapt the factory offerings.
oldsfromyell is offline
Old January 3rd, 2016, 07:25 PM
Octania's Avatar
Exhaust manifolds?
Not likely. What if you were to use Toro manifolds, single outlet, turn them over to place the outlet up and forward. Then cut and weld to adapt the turbos.
This is going to be some seeeeerious fabrication.
I would imagine that the bottom end should be stout as you can afford [x2] if you want to run any serious boost, and enjoy the fun that comes with that. I defer to those with lots of forced air engine experience.
Octania is offline
Old January 4th, 2016, 04:27 AM
cutlassefi's Avatar
What is your hp goal for this setup?
cutlassefi is offline
Old January 4th, 2016, 11:43 AM
Originally Posted by Octania
Exhaust manifolds?
Yes exhaust manifolds or fabricate your own headers. Yes lots of wonderful fabrication work. Hours of endless fun.
Old January 4th, 2016, 12:59 PM
Mr Nick's Avatar
Does it have to be twin turbo?
Mr Nick is offline
Old January 5th, 2016, 11:56 AM
madmax442's Avatar
D/DX Diesel Block at minimum unless your goal is for 600-650hp or less and that's pushing it on a production gas block of big or small variety! Gonna need a good set of forged pistons and rods and possibly a custom crank depending on hp levels. Also will needs a good ignition to light the fire as well! This is a big dollar build unless you have tons of accumulated parts already!
madmax442 is offline
Old January 5th, 2016, 02:31 PM
captjim's Avatar
It sounds like the OP is doing this more for the "cool factor" than for high HP. It really is hard to make the math work with the lack of production parts available. I went through the same thing trying to make a street blower make sense. It just costs too much in time and parts just to add 100 hp and 125 ft/lbs unless you go for a high end build, better off with a stock 468 or even a 496.
captjim is offline
Old January 5th, 2016, 03:13 PM
madmax442's Avatar
I should have added that you can make gas blocks live with full girdles for big power but apparently I forgot to add it in my last response. I can honestly say that I think that single turbo build on V8TV is pretty awesome! BTR put that together and they figure it's 700+ hp! If you got the cash for a quality boosted build then by all means do it! I know it's going to take awhile before I can get my boosted NASCAR build off and running! Just don't be surprised at the house sized expense! I hope you go and do it! Twin turbos would be cool, just ask Gene Newton!
Old January 5th, 2016, 04:23 PM
Rocket Renegade!
What are you starting with?
BangScreech4-4-2 is offline
Old January 5th, 2016, 06:26 PM
ctosiflying's Avatar
There are a few twin turbo Oldsmobile powered cars on YouTube. Some are built on a budget.
ctosiflying is offline
Old January 5th, 2016, 06:27 PM
Old January 6th, 2016, 04:49 AM
madmax442's Avatar
Somebody pull up Gene Newtons Twin Turbo 1400hp NASCAR 442! That thing rips!
Old January 6th, 2016, 07:48 AM
young olds's Avatar
young olds is offline
Old January 6th, 2016, 07:50 AM
young olds's Avatar
Old January 6th, 2016, 07:56 AM
young olds's Avatar
Old January 6th, 2016, 07:57 AM
young olds's Avatar
Old January 6th, 2016, 08:31 AM
madmax442's Avatar
Awesome stuff!!!!!
Old January 6th, 2016, 05:50 PM
young olds's Avatar
Markd built some sweet engines, especially that 900ft-lbs torque monster. Genes car is no joke either
Old January 6th, 2016, 05:54 PM
madmax442's Avatar
I live in New England so I hope to meet Gene someday at Epping dragway in NH! He should be in street outlaws with that thing!
Old January 13th, 2016, 04:35 PM
therobski's Avatar
That's the stuff that flips my switch. I have a 65 425 block, unturned steel crank and a bunch of parts, including Aris custom made pistons, Joe Mondello Rods etc.-maybe the 64 F-85 pro touring car deserves it???? Every thing on the car including the 200-4R will handle the power. ( except for the converter and a roll cage) I'm 3-4 years from retirement don't know if I want to spend the $$$$
therobski is offline
Old January 13th, 2016, 06:23 PM
Rocket Renegade!
Well, somebody must have talked OP down from it. He hasn't been heard from since the 3rd of the month.
TwinTurbo455
January 19th, 2015 07:13 PM
Octania
September 24th, 2014 07:38 PM
815Cutlass1972
March 3rd, 2012 06:22 PM
1965cutlassragtop
June 8th, 2011 03:27 PM
Aceshigh
Non-Olds Engines
January 11th, 2011 05:14 AM
Quick Reply: Twin turbo HELP!! 66 442
