Supercharger 65’ 400
Old May 9, 2024 | 01:56 PM
442nick's Avatar
Hi everyone, I am looking for any information about supercharging a 400ci big block it’s a 1965 block it has the stock heads which have had a full refresh ported, new springs, valve seats, valves everything, block has been sleeved, oil restrictors to cam, eagle rods forged pistons, double chain timing chain, melling oil pump about 10.5:1 compression but I’m unsure about if any company’s make blowers for this or something used from the 70s any info helps thanks
Old May 9, 2024 | 05:22 PM
cutlassefi's Avatar
Yes, do a search and you’ll find most people use the old Offy intake as a base. From there you’ll be able to find a blower. Or you could always do the Torqstorm system.
But with 10.5:1 compression you won’t be able to run much boost at all on pump gas.
And too bad you wasted money on the oil restrictors.
Old May 10, 2024 | 04:19 AM
Oldsmaniac's Avatar
Check out Hampton Blowers
Old May 10, 2024 | 07:41 AM
therobski's Avatar
Mark , will the lower half of a 400E hold up well, even if the compression was lowered??
Old May 10, 2024 | 12:00 PM
cutlassefi's Avatar
How much power are you looking to make?
mrb2872
Sep 1, 2022 07:35 AM
67Rocket
Feb 13, 2017 08:48 AM
Bob Kelso
Apr 17, 2015 04:02 PM
stonecad
Nov 13, 2013 06:04 PM
Oldzman71
Oct 16, 2013 02:48 PM
