Standard manifold to RPM
Old Jul 4, 2017 | 06:42 PM
garage goat2's Avatar
I was wondering if I switched to an RPM from my stock manifold (olds) .
What would I have to do to the carb to make it run right? And if I need to rejet how would I go about it it. Would I go richer or leaner?
I know read the plugs right , I'm wondering if someone has done this already.
Oh and it has headers so it will run good.
Old Jul 4, 2017 | 07:12 PM
coppercutlass's Avatar
Chevy budget Olds powered
No gains unless the engine is taylored for It like , cam , compression, cam etc. A performer is better suited for a stock to mild build.
Old Jul 4, 2017 | 07:29 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Some claim gains on Vin 9 307's, others claim it is overkill unless you have cam and compression. What compression and cam? It won't hurt anything and jetting will stay the same without other changes.
Old Jul 4, 2017 | 07:55 PM
I have the cam and flat top pistons as well as headers. And 3:73 gears.
Old Jul 4, 2017 | 08:02 PM
will work great. i run a 750 holley double pumper box stock with a flipped pink cam.
Old Jul 4, 2017 | 08:06 PM
I had to adjust the idle and the secondary air door spring. Apparently the air flow at WOT was quite different and the secondaries had to be adjusted.
Olds1971
Apr 25, 2022 02:32 PM
Takid455
Mar 2, 2014 07:27 PM
wcourt3010
Oct 2, 2012 12:50 PM
steve19
Nov 30, 2008 11:05 AM
oldsmoenewbie
Oct 28, 2006 04:46 PM
