Short Deck block Oldsmobile
#81
#83
Canadian olds I thought people from Canada where supposed to be nice. I was just thinking outside the box on why I felt a certain way about a thing. But it honors me my words mean that much to you. For that thank you very much sir.
#85
#87
#89
I'm gonna bring one thing up. You guys brought up there being issues with fuel which I think people amount to cheating. And people get hung up on what type of car or wether it was a rail or a door car. Let's face it if you are gonna go that fast at that point yeah it's gonna be far from stock. My 72 weighs in at 3285 with me in it and half a fuel cell 8 gal. People consider that unrealistic but that's part of what it takes to go fast. Well relatively. 11.60's with a 350 . My car is still mainly steel. Only the hood and deck lid are fiberglass. I just wanted to say that because I gets old on wether or not it's door car or rail. The fastest cars are top fuel dragsters and funny cars. Do people discredit then because they are not door cars ???? And for Canadian olds yes I spin my 350 to 7k. Had to remind him 😂
#90
#91
#93
#94
If thats the CN build it looks good to me, but your 350 Olds build looks good to me as well, but I think my NA 327 shop truck might run right with it............................
#95
Vortec pro. How long will it last. I know stock eliminator has come a long way in terms of rules and what not but don't they run those engines on the ragged edge loose and what not so they don't really last long ??? . Curious on that.
#96
My shop truck has just under 30,000 miles now, drive it almost every day, use it to go to the dump, use it to go to the track and run 11s, and I think its worth mentioning its all production parts as is your Olds. My stock eliminators cars only get raced so I can't tell you how long they would last. Piston to cylinder wall clearance would be loser than a dailey driver but nothing crazy. The truck is getting a 355, it will be quite a bit quicker.
#97
Simple question. How many runs before you have to teardown to inspect and freshen up. Also how many runs . I got 150 runs on my 350 and maybe 2500 street miles and I'm gonna try one more season I'm just gonna change valve springs.
#98
I would freshen a engine IF it were to slow down, that doesn't usually happen, the engine comes out when I want try or test something new. I dyno test engines before they go into the car and after they come out. I did have a 455 slow down after 3 years of flogging the car, it slowed a tenth, it was down on the dyno 14 HP, upon tear down the the ring lands had worn. The radial thickness of the rings were cut down.
#99
It's been 4 years since the engine went into my olds that's in there now. It's been good and the MPH is still the same as day 1. Last fall matched our best e/t in the fall after racing 10 points races. And next year I'm gonna do appx 14 races. 12 at home 2 elsewhere. If it survives and looks good when it comes apart it's getting a stroker set up.
#100
enlighten me
#101
which is probably around 6200, at 7k it’s maybe making 320
it isn’t making enough to hurt itself, you could probably kiss more than 7k and it still stay together…your valve springs are still ok.
making good power at 7k is totally different than being on the backside of the hp curve and the rotating assembly going along for a ride because of valve springs .
#102
You gotta factor percentage loss since the numbers would be at the wheels. Not the fly wheel when using track numbers. And even then they will vary because I'm transferring the power fairly good. So it's win win . I either A. Have a killer set up that puts the power down good for having nothing sophisticated or I have a good engine combo. Either way you look at it. It's win win because I built the whole thing front to back
#103
With the available power you have right now you could close the gap between showing 360 to 400 HP by changing your drive line setup, but you choose not to, I understand this is a bracket car.
#104
Idk 1.56 60 ft. With a 3.90 is pretty damn good for what it is. I don't need endless explanations. I figure it out as I go because experience is the best teacher. Same reason I usually work alone. I don't need a bunch of people telling me what to do or try. I just go for it. Either way car has done what it needed to do and beyond anyone's expectations so I'm fine with being wrong on all ends because I gotta be doing something right to be where I'm at. It's the internet you think I'm gonna take you serious ????
#105
Just trying to help you even though we don't like each other, I think you have potential. You do need explanations because your not getting it, understanding HP observed is very important to going faster. A lot of times I'm just trying to get you to look at whats out there. Example: yes a 1.56 looks good to you, but when theres cars 250 heavier with 440 HP small blocks going 1.38 60s I see it different. Its not that your wrong, maybe you can incorporate a few of these things into your operation. Either way your running good, but I think you have more potential.
#106
I never said I didn't like anybody. I've butted heads with mark over the years and we don't see eye to eye but I still respect him as someone who does what he does . When I go back through my current engine I plan on using his stroker crank and rods. Pistons if I need them. I will tell you f**k you to your face and then ask if you wanna have a beer. I don't hold grudges nor do I really care to.
#107
#108
what a clown you are..because someone blows your need for an aluminum block down the toilet, you say it’s negative?
what have you ever done to make you think you need a new aluminum small block that cant be done with the blocks available now?
let’s hear about your accomplishments in the Olds engine world..they must be quite something.
when you show us you broken either of the blocks available now, I’ll change my mind 🤣🤣🤣🤣
#109
We will now return to as the world spins according to canolds. Because that where all his post come from a out house can . You are so much like votec I still think you are twins. I still think a aluminum block could be a good thing. Small block or big block. If I had the cash which I don't I think I would go billet. Then have billet heads made also. While I am dreaming about this why not do both bbo/ sbo . Set these engines up with twin turbos. Okay when I hit the lottery some day. LOL
#110
let’s here about your dream block and billet heads bwahahahhaha
#112
still waiting for yours or where to find them
#113
#114
#115
tour real name is wr1970? That’s funny
#116
#117
#118
Can I have a hint to get me started ? Hahahahaha
#119
There is four sticky threads on this forum.
At the front of this forum Racing and high performance. I guess if you can't find it with this info and being a tech writer that you claim there is no hope for you .😂😂😂😂😂😂😂😂😂😂😂
#120
