Rpm intake 1969 cutlass
Old Feb 27, 2026 | 11:39 AM
ej69's Avatar
Will an Edelbrock RPM intake on a 350 olds fit under stock hood of a 1969 cutlass. Thanks for the help -
Old Feb 27, 2026 | 03:35 PM
Mr Nick's Avatar
Yes. I can't comment if it will fit with a stock air filter assembly, but I've used a few different styles of 14" open filter housings without issue.
Old Feb 27, 2026 | 03:41 PM
ej69's Avatar
was planning on using open element w drop base
Old Feb 27, 2026 | 05:41 PM
VC455's Avatar
Barely Registered
We can't predict accurately. because we don't know the measurement of your drop base cleaner.
But it won't take long for you to get the answer.
Measure your current clearance by closing the hood over loose-balled aluminum foil set on your air cleaner
Then calculate:
  • The Edelbrock 7111 is 2" taller than a stock 4bbl intake manifold. So, subtract 2" from your clearance number.
  • Compare the measurement from the carb ring to the top of the filter on your drop base air cleaner and on your stock air cleaner.
    • If the drop base measure is shorter than stock, add that number to your clearance.
    • If the drop base measure is greater than stock, subtract that number from your clearance.
If you get a positive number, that's your new clearance.
Good luck!
Old Feb 28, 2026 | 07:49 AM
Duh's Avatar
Duh
Like said above measure what you have. Playdough works great too. You put it on top of the air filter and close the hood and measure. You can also use your cell phones camera to take a look. Place a work light in the engine bay and put the phone in while taking a movie. This what you can see too.
Old Feb 28, 2026 | 01:25 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Another reason why I like the taller raised sport hood, which mine 1970 has. I fit a RPM and Qjet using a stock later 307 air cleaner I converted to dual snorkel with a 260 snorkel. The 3.5" tall 14" air cleaner with a 1" drop clears my hood, 7111 intake and Qjet. Also Motor mount condition also plays a factor, clay is your friend, it may be close with the regular flat style hood.
Old Feb 28, 2026 | 07:31 PM
70sgeek's Avatar
'72 Cutlass ragtop
Will you be using a hood insulation pad on the underside?
Your clearance may be similar to the 70-72's and if so, my 14" air cleaner on a drop base atop a Quick Fuel carb and 7111 intake fits underneath my '72 with an OEM louver hood and a decent insulation pad. It does leave a minimal imprint on the pad but no closing issues with a 3" air cleaner element.
Old Mar 1, 2026 | 01:45 PM
bigrbandit's Avatar
72 Cutlass Ponca City OK
drop base air cleaner fits with 7111 just fine.
Old Mar 22, 2026 | 12:40 PM
maddoctor's Avatar
Valve covers
Can I ask where you go those awesome valve covers??
Old Mar 22, 2026 | 07:24 PM
2qwk4u442's Avatar
Old'S-Kool
maddoctor, those are from Performance Driven Design. And yes they are awesome, I've been drooling too ...lol
https://www.performancedrivendesign.com/
Old Mar 23, 2026 | 06:29 AM
Gorgeous valve covers, love the W43 style pattern. You definitely pay for the quality and I'm sure aluminum has gone up a lot in recent months.
vikingharley
Feb 14, 2021 05:57 AM
Mojo4892
Mar 20, 2016 07:32 PM
smietana
Mar 19, 2014 12:56 PM
Her69olds
Dec 14, 2013 09:20 AM
