Radial Drag Slicks
Radial Drag Slicks
I have to replace my M/T Bias ply ET drag slicks, however the size I want is on backorder with no firm restock date. I can get the Radial ET drag slicks now. I've been reading the Radials can be faster but are harder to hook and may require dialing in suspension to get them to work as desired. My 442 is all stock suspension and not adjustable. While I had no problem using bias ply slicks, should I expect to have trouble hooking up if I switched to Radials?
Thanks.
Thanks.
That really depends on 2 things.
-power level
-wheel size
without those two things there’s no way to tell.
If you were on the ragged edge of losing traction with slicks then radials may not work without ANY adjustments.
-power level
-wheel size
I ran Hoosier 28x12.5 Quick Time Pros for years. The last set of shoes I bought for the car are 295/65 Et Streets. I have to say I’m impressed. They flat out work, and if you have to drive on the street with them they are much better. They fo like more air than the Hoosiers did, if I remember correctly I ran 19 psi.
The best 60ft with the Hoosiers was a 1.56,the ET Streets was a little better at 1.54. Better 60ft, better ride, and no sway on the big end is a win win in my opinion.
Thanks.
Thanks.
https://www.summitracing.com/parts/H...xoC7XEQAvD_BwE
Bias do recover easier, yes. Radials can be quicker and faster. Depending on the car they can both be equally consistent. Depending on the car, HP and transmission radials can be harder to set up. If you car is currently dead hooking they will most likely work without issues.
As for using radials with a munal transmission it's not a problem with the right clutch and suspension. It's not recommended with most manuals due to the fact that if you need wheel speed you will blow the tire off or if it does dead hook the shock to the drive line is more violent.
boese1978
April 5th, 2021 12:56 PM
safray
Wheels and Tires
February 21st, 2017 12:50 PM
