PDD CCN manufacturing
Old Jan 28, 2024 | 08:07 PM
Bernhard's Avatar
Old Jan 28, 2024 | 08:11 PM
Bernhard's Avatar
Old Jan 28, 2024 | 08:12 PM
Bernhard's Avatar
Old Jan 28, 2024 | 08:21 PM
66-3X2 442's Avatar
Peyton Hunt has it goin on doesn't he? Great young man too.
Old Jan 28, 2024 | 09:28 PM
Bernhard's Avatar
That's some very impress parts manufacturing. I'm looking forward to this build as well as others on Facebook.
Old Jan 29, 2024 | 04:55 AM
chadman's Avatar
Originally Posted by Bernhard
When I look at this I can't help but think of all of the oil and dirt that's going to end up in the pockets on that valley tray. Definitely some nice machine work though.
Old Jan 29, 2024 | 09:11 PM
v8al's Avatar
Registered Olds Owner
Personally, I like to see heads that have holes drilled for the accessory brackets. Though for all out race I understand why they are not present.
Old Jan 29, 2024 | 09:39 PM
Bernhard's Avatar
Motor plate at this power level.
Old Jan 30, 2024 | 05:56 PM
Mr Nick's Avatar
Some sort of removable plate at the end of the heads?
Old Jan 30, 2024 | 06:53 PM
olds_freak's Avatar
But the question EVERYONE wants to know is: Will these clear a mechanical fuel pump?
Old Jan 30, 2024 | 06:54 PM
olds_freak's Avatar
Yes. They're billet so they have to do that to be able to machine water passages.
Old Jan 30, 2024 | 08:20 PM
66-3X2 442's Avatar
Absolutely!!!!!!!
Old Jan 30, 2024 | 08:24 PM
Bernhard's Avatar
Nice LOL
Old Jan 30, 2024 | 08:37 PM
CANADIANOLDS's Avatar
post any build info if you know
Old Jan 31, 2024 | 04:21 PM
Battenrunner's Avatar
Those are some gorgeous pieces.
Has he released any info about cross-section area, flow numbers, pricing, etc?
Old Jan 31, 2024 | 05:30 PM
66-3X2 442's Avatar
They have a website.
Old Jan 31, 2024 | 06:12 PM
I didn’t know they have a website separate from Facebook. I am not on Facebook, and I couldn’t open their Facebook since I am not on there.
here is a link to their website, for others who don’t want to be trolled:
https://www.performancedrivendesign.com
Looks like the heads start at $10,500, and that doesn’t say what all is included or done to the heads.
Really nice stuff from him in general. If I had the funds, I would do the heads on a Rocket block.
Old Feb 1, 2024 | 03:27 PM
the heads would be designed for your specific app. So wanting to know what they flow or anything else would need your engine details and power goals
there is such a thing as too big of a port and valve for an engine. Those heads on a 400” short stroke or a big 540” big block would be different. Min CSA and max intake valve size is critical…even though many experts on here don’t know what that even means. Air speed through the intake port needs to be right for the cyl volume and rpm..if it , it could be lazy , peaky..or be a dud all together
the reason you see flow numbers for Edelbrock and Speedmasters is because they are usually low on flow #s even after a max port when installed on a big block…they need to be blasted out so the engine doesn’t fall on its face up top.
Old Feb 1, 2024 | 03:41 PM
They heads are an ODE to ROP😂😜
that’s great…😎
Old Feb 1, 2024 | 06:19 PM
yessir…sounds like they are fully custom and optimized for each build, which makes them really even more impressive.
I do know a wee bit about that max intake valve size to CSA ratio, but I do appreciate your info and sharing.
Yep, getting these weezy-azz Olds factory port location heads above 300cfm takes a lot….
Even the Battens don’t usually go much above 380cfm with max effort and .800 lift, at least for ones I have heard about and spoken to people on.
Old Feb 1, 2024 | 09:04 PM
66SportCoupe's Avatar
Pick a nice big build and figure out other things needed for a smaller build. Pretty simple.
Old Feb 1, 2024 | 09:42 PM
what?
75 W-30 H/O
Nov 18, 2023 01:37 PM
tkcutlass
Sep 20, 2023 08:09 PM
75 W-30 H/O
Nov 23, 2022 03:47 PM
72455
Mar 14, 2022 12:42 PM
