Modern machining tolerances
Old Jan 22, 2023 | 07:46 AM
Alaska442's Avatar
What is the tolerances people are using for a performance build these days.
I have a steel 455 crank and H beam eagle rods and a set of Valasco 4.260 BBO pistons that weigh 490 grams
what main and rod bearing clearance as well as ring gap and bore for a street strip build.
Old Jan 22, 2023 | 02:20 PM
cutlassefi's Avatar
With 4.260 pistons the first thing I would do is sonic check the block. Then worry about clearances after that.
Old Jan 23, 2023 | 08:41 AM
Alaska442's Avatar
,134 over size Bore for these pistons is going to be close, thanks for the information.
I was wondering if the agle rods make any diffrence on machine specification -most olds engine builders recomend looser tolerance for rods and mains. From what i remeber.
mains-.0035 to .004
Rods -.003 to .0035
Not user about the eagle Rods though.
Old Jan 23, 2023 | 09:50 AM
cutlassefi's Avatar
mains-.0035 to .004
Rods -.003 to .0035
With Eagle rods and studded mains I shoot for .0027-.003 and .0032-.0035 respectively.
Old Jan 23, 2023 | 09:58 AM
chadman's Avatar
X2. I like those numbers for a street type build and a tad looser for race only stuff.
HarrySlother
Dec 7, 2021 02:51 PM
coppercutlass
Jun 10, 2021 08:06 AM
Alaska442
Mar 14, 2021 06:18 AM
sparky72
Apr 19, 2015 07:03 PM
Al2011
Feb 23, 2012 06:52 AM
