Gas Small Block with C Heads BTR Build
Old Oct 7, 2022 | 04:23 PM
Bernhard's Avatar
BTR build using Mark's 4" stroke crank and C heads.
Gas block ,victor intake, 4.125 bore
This was posted on Facebook
Old Oct 7, 2022 | 05:08 PM
cutlassefi's Avatar
Although a little low on tq, in my experience these are pretty typical numbers for the combination.
Y’all still want to believe Peter Graves’ numbers after seeing these? Knock your selves out.
Old Oct 7, 2022 | 07:51 PM
Bernhard's Avatar
I thought the numbers were quite good given the mildly ported cast iron C heads and small camshaft. Very nice street engine with those TQ numbers.
Old Oct 8, 2022 | 01:22 AM
fleming442's Avatar
Who is Peter Graves?
Old Oct 8, 2022 | 03:49 AM
deadeyejedi's Avatar
James Arness brother
Old Oct 8, 2022 | 03:51 AM
seriously , how can i blow up this document ?i cant read it and see no option to zoom in .
Old Oct 8, 2022 | 04:27 AM
cutlassefi's Avatar
Lol!!
A post was done earlier about a guy (Peter) that used one of my Stroker kits. His Dyno sheet showed 552hp and 592tq corrected.
The combination was a 434, 10.5:1, 227/233@.050 cam, ported small block irons, RPM Intake and an 830 carb. I argued that based on my own experience his numbers were unrealistic. A couple of people said no.
Old Oct 8, 2022 | 04:33 AM
cutlassefi's Avatar
I agree. It’s just that I personally haven’t had one make less than 500tq with any of the half dozen configurations I’ve done.
BUT I don’t know where he degreed the cam etc. and it looked like Bill took a fair amount of material out of the flange area of the intake. That COULD effect low end tq.
Bottom line is his customer is happy and that’s all that matters.
Old Oct 8, 2022 | 06:46 AM
Bernhard's Avatar
Old Oct 8, 2022 | 07:04 AM
Bernhard's Avatar
Bernhard wrote:
Mark have you built any using the factory small or big block cast iron head?
Old Oct 8, 2022 | 07:50 AM
cutlassefi's Avatar
Yes, a couple of months ago. 429ci, 10.2:1, 234/240@.050 Hyd roller, RPM intake, 850 Brawler, big valve E heads with a bowl blend.
Made 488hp/518tq.
Old Oct 8, 2022 | 08:28 AM
Rallye469's Avatar
I bet its more that 500ftlbs at 3500 rpms
Old Oct 8, 2022 | 08:33 AM
Bernhard's Avatar
Made 488hp/518tq.
Nice
Did you post the build?
Old Oct 8, 2022 | 11:21 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I was wondering the same thing.
Old Oct 8, 2022 | 11:30 AM
VORTECPRO's Avatar
Wheres the rest of the page?
Old Oct 8, 2022 | 01:01 PM
Bernhard's Avatar
Mark that's all that was posted.
Old Oct 8, 2022 | 03:49 PM
cutlassefi's Avatar
Nice
No I did not.
Old Oct 8, 2022 | 03:51 PM
cutlassefi's Avatar
Why don’t you demand to see the rest from Bill like you do me? Go ahead, let us know what he says, if he answers you at all.
Old Oct 8, 2022 | 04:04 PM
cutlassefi's Avatar
I’ll bet it’s not..You ALWAYS throw out the first and last numbers. Always.
I’d say max tq was 489, Notice how that number is predominant after the start of the pull. That’s most likely your peak, especially with peak hp coming in at 6500..
Old Oct 8, 2022 | 06:21 PM
VORTECPRO's Avatar
If he was on here I'd ask him.
Old Oct 9, 2022 | 04:44 AM
cutlassefi's Avatar
And when he didn’t comply, and/or mentions that his customer isn’t going to race it either, you’d settle for that? There are many on here, including me, that don’t believe that for one second.
Old Oct 9, 2022 | 05:40 AM
VORTECPRO's Avatar
Either he will post the whole dyno test or he won't. And feel free to forward my questions to where ever this test is posted.
1. RPM at which HP peak is derived at. Why is it much higher than yours with the same crank and big cam?
2. Why is it using only 194 lbs of fuel at peak HP?
The HP in this test seems very reasonable, the RPM at which power is derived at leads me to ask more questions.
Old Oct 9, 2022 | 07:18 AM
cutlassefi's Avatar
I agree. But I’m not going to beat a dead horse on it like you do, mainly because he probably won’t answer anyway. I’ll find out for myself.
You seem to critique a lot of these. Why don’t you build some of these same combinations yourself instead of just sitting on the sidelines and throwing stones? Or better yet, just move on.
Old Oct 9, 2022 | 02:47 PM
CANADIANOLDS's Avatar
Did all the specs get posted, like comp ratio, cam specs and bead flow plus more?
Im not seeing it here
Old Oct 9, 2022 | 03:10 PM
Bernhard's Avatar
Cam specifications 230/236, .580 lift, 108. Pump gas 93 octane
Old Oct 9, 2022 | 03:16 PM
need the comp ratio
Bernhard's Avatar
Old Oct 9, 2022 | 03:22 PM
Bernhard's Avatar
Old Oct 9, 2022 | 03:28 PM
Bernhard's Avatar
need the comp ratio
The comp ratio is not listed I will ask.
Old Oct 9, 2022 | 05:18 PM
cutlassefi's Avatar
10.7:1. It’s listed in the main text. Heads got a bowl blend with the larger valves.
Old Oct 9, 2022 | 10:19 PM
  #31
Bernhard's Avatar
Bernhard wrote:
Thanks Mark I missed that.
428 Small block Olds. 4.125 bore 4 inch stroke C heads bowl ported, 10.7:1 hyd roller, Victor.
Old Oct 10, 2022 | 05:29 AM
  #32
cutlassefi's Avatar
No problem.
Old Oct 10, 2022 | 05:46 AM
  #33
Have you done any with a Victor and iron heads that made more than 500tq?
Let’s see….one will do
Old Oct 10, 2022 | 06:23 AM
  #34
VORTECPRO's Avatar
Dale
The numbers mean nothing from either of them without supporting data..........
Old Oct 10, 2022 | 06:48 AM
  #35
cutlassefi's Avatar
Nope, you?
Quite frankly I thought it would be at least a bit more, especially due to the fairly high compression ratio. But I also mentioned that I didn’t know where the cam was degreed as well as the amount of material removed from the intake flange area. But that’s why we do different builds right, to see what the results will be?
Note; I also asked about the peak numbers going from 509 to 507 to 511, just curious. Scotty G’s response was;
“The dyno is cantankerous like it’s operator 😳”
Thanks.
Old Oct 10, 2022 | 07:31 AM
  #36
fleming442's Avatar
What was the coolant temp? 🤡
Old Oct 10, 2022 | 07:45 AM
  #37
cutlassefi's Avatar
Freezing😎
Old Oct 10, 2022 | 08:14 AM
  #38
Dale
i know..but do we need data to be told a dual plane will make more low end TQ?
im not talking about how accurate the numbers …I’m talking about the facts of life
Old Oct 10, 2022 | 08:32 AM
  #39
Nope, you?
Thanks.
so you haven’t, gotcha.
comparing low end TQ of a dual plane to a Victor isn’t similar either then is it?
and yes, I have done builds with irons and a Victor, both small blocks and big blocks
Old Oct 10, 2022 | 08:44 AM
  #40
Bernhard's Avatar
You have been on a roll of late LOL
