Flat tappet recommendation
Old Jan 5, 2023 | 02:11 AM
dragline's Avatar
What are the best flat tappet cam lifters available right now for a 455? I've heard the quality control isn't so good on some brands.
Old Jan 5, 2023 | 07:04 AM
VORTECPRO's Avatar
I use vintage lifters, you can find them if you look. I use Redline for my cam grinding, he also uses older cam cores when possible.
Old Jan 5, 2023 | 06:37 PM
cutlassefi's Avatar
The cam cores aren’t the problem. The biggest causes of lifter/cam failure are by far and away improper spring pressures and the crown, or lack there of, on the lifter.
I don’t use a lot of flat tappets but I’ve had 0 issues with both Comp cams and Topline/Hylift lifters.
Hope this helps.
Old Jan 6, 2023 | 12:24 PM
CANADIANOLDS's Avatar
I try to only use hard face bottom lifters. Comps pro Magnums are hard faced. Anything over 300 open I get the core nitrided. That combo lasts for years
h
Old Jan 8, 2023 | 10:38 AM
dragline's Avatar
Thanks for the input everyone, I've heard of engines grenading lately from poor quality lifters.
onofre442
Apr 9, 2022 09:56 PM
1968Cutlass_S
Mar 18, 2018 04:43 AM
Cpriester123
Nov 8, 2016 05:46 AM
RROLDSX
Mar 8, 2013 05:50 PM
nonhog
Feb 21, 2010 09:21 AM
