Exhaust Cutouts and 1/8 Mile Fun
Old Oct 18, 2024 | 09:50 AM
  #41
CustomBruiser's Avatar
Thanks!
Old Oct 18, 2024 | 11:47 AM
  #42
Originally Posted by jmcghee
Any pics of the exhaust?
This is what it looked like before putting it in. Now the muffler is of course different.
Old Oct 18, 2024 | 04:34 PM
  #43
Lonnies Performance's Avatar
Lonnie did that Z have cats?
No cats.
Old Oct 20, 2024 | 09:31 PM
  #44
69CSHC's Avatar
Originally Posted by CustomBruiser
I've got updates. I made a few improvements and headed to Milan yesterday to test them out and have fun.
Sweet, nothing better than coming back from a track session with new bests. You are getting very close to a perfect pass. When calculated hp from the et and mph match each other from a maxed out drivetrain and clean run.
You are approaching 400 hp in performance. Depending on build, is that where it should be ? You are showing 385 net hp at the crank with your best pass. I'm figuring the build may be around 425 hp gross ? Seeing that open headers is a key to both your best pass and a gross crank dyno. Only difference for you is accessories.
101.52 is good for a 13.05 so obviously you are darn close. And still worth it as is for you to keep trying. I need a significant change on my ride to make going back really worthwhile. Especially when the track and weather was as good as it gets on my best.
Weather also played a part in your gains. The DA was phenomenal towards the end of the day for your last session. If you can provide time stamps for best runs from both recent sessions I can really crunch numbers. That's assuming time stamps are accurate. Sometimes they are not. One of the reasons I took detailed notes on my passes.
Old Oct 24, 2024 | 11:43 AM
  #45
I don't really have a reference, but it seems reasonable, I think.
It's a 9.5:1 455 with a Crower 284HDP grind, big valve K heads that I ported and cut to 78cc, long tubes, a Torker intake and a 780 Holley
mb13
Mar 25, 2024 05:42 AM
tgilligan
Mar 11, 2020 09:31 AM
Platinum69
Mar 29, 2019 03:40 PM
csouth
Sep 11, 2009 07:30 AM
silverriff
Sep 30, 2008 03:30 PM
