Eagle Rods and the small bore 400 G.
Old Apr 25, 2021 | 08:23 AM
Bernhard's Avatar
First off I want to thank grannys442 for posting this very helpful information.
https://classicoldsmobile.com/forums...73503d-154892/
The Eagle Rod and most likely all of the entry level offshore rods will have the same issue. The big end is to large for the small bore.
Is removing material from the side of the rod a viable option?
It would weaken the rod but would it weaken the rod to the point of failure given the 400 G HP/TQ limitations.
Old Apr 25, 2021 | 12:27 PM
cutlassefi's Avatar
Speedmaster H beams will fit, approx 3.865 across the big end.
Old Apr 25, 2021 | 12:40 PM
Bernhard's Avatar
Thanks Mark for the reply.
Where do Speedmaster H beams rank on the quality scale?
https://www.speedmaster79.com/H-Beam...le-400-425-455
Old Apr 25, 2021 | 02:29 PM
cutlassefi's Avatar
Good quality overall but sizing not so good on the big end.
Old Apr 25, 2021 | 03:00 PM
Bernhard's Avatar
Old Jul 17, 2021 | 10:47 PM
CANADIANOLDS's Avatar
Its hit and miss with speedmaster quality. got a set here that 3 of the rods are poorly machined on the beams. really rough and a lot different thickness variation side to side. one side is .075' thick while other is.125" and i dont know the real quality of the bolts.. no name and a real rough head on it.
still better than using a stock rod though.
Old Jul 18, 2021 | 03:48 PM
Bernhard's Avatar
Thanks for the reply its good to know what to expect from a speedmaster rod.
Old Jul 18, 2021 | 04:18 PM
cutlassefi's Avatar
Yes lately they’re not so good, consequently I’ve quit using them.
Big end widths ranged from .925-.937. Way too much variance. I sent them back.
Old Jul 21, 2021 | 07:45 AM
Bernhard's Avatar
Mark have you had a chance to measure the big end of the Scat rod for cross sectional width?
Old Jul 21, 2021 | 02:43 PM
cutlassefi's Avatar
I did but forgot what it was. I’ll try to grab a set and do it again.
anoldsman
May 21, 2021 11:08 AM
grannys442
Apr 24, 2021 07:12 PM
olds 307 and 403
Jan 12, 2016 02:25 PM
ferndaleflyer
Apr 14, 2013 06:53 PM
csouth
Jan 4, 2010 07:04 AM
