Cam help!!
Old Feb 19, 2014 | 07:49 PM
KDW's Avatar
KDW
Cam help!!
what would be a better choice for cam?
its a 455 .30 forge pistons 9.1 Edlebrook heads, performer intake , 750 QF, th400 307 gear..I will be changing gear and stall..this will be a weekend driver only with a/c inned it to go and sound good
I'm looking at
voodoo 60803
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 227/233
Gross Valve Lift (Int/Exh): .510/.522
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1600-5800
Modello jm 20-22
0.4960.512266°/274°226°230°110°1400-5800
Modello jm 20-25
0.5120.523274°/280°230°236°108°1400-6000
im open to a recomindation Comp cam etc
Old Feb 19, 2014 | 08:04 PM
70cutty's Avatar
Beer Connoisseur
Talk to Mark(cutlassefi) he can get you a cam. He helped me and many others.
Old Feb 20, 2014 | 08:59 AM
Wise Performance's Avatar
I used a cam very simular in a 355 SBO, ran well sounded great, I believe it will work for your application.
I prefer a 60811 or 60812 Hydrolic roller for better performance and power.
We also offer a custom WPE .842 Hydrolic roller lifter, WPE 3/8 cro-moly pushrods and Roller rocker in a kit to match. .02
Old Feb 20, 2014 | 01:30 PM
captjim's Avatar
I had that cam in a 10.25 to 1 355 and loved it. You could hear it but great manners and driveability. It should be great in a mild 455. Some say (Mark) that the steep ramps are hard on the valvetrain, perhaps true. And, a roller IS better, if you can afford it.
67flamedcutlass
Dec 19, 2019 07:54 AM
grmchne78
Jun 25, 2015 06:23 PM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
66 Olznut
Mar 9, 2008 12:30 AM
