BTR Heads
I'm trying to figure out what's going on there with the rocker arms. They are obviously offset but what I don't get is why they aren't symmetrical from one end to the other? I have a set and they are a mirror image from one end to the other.
Chadman I think Bill moves the pushrod tubes “out of the way a bit” which isn’t the same on every port. You can see amount of epoxy on the top. That tells me a lot has been changed there.
Jmo.
The set I have are for moved pushrods as well. I'm just trying to figure out why they wouldn't be moved the same from one end to the other. I could see the inner ports possibly being different from the outer ports but I don't see why they wouldn't be a mirror image from end to end.
I think it may be because of the spacers that have to be between the rockers on the shaft and the way they line up with the push rods.
But I’m not 100% on that.
I do know that Bill starts out with raw castings and machines everything in the position he wants.
Blank canvas.
-p
Blank canvas.
-p
Blank canvas.
-p
Blank canvas.
-p
I’ve been super slow getting my junk back together. Finding the ‘65 up in Tennessee slowed me down by a week.
Just trying to clean things up as I bolt it all back together. But it’s getting close. Should start it up tomorrow night.
Not fond of how tall this victor is…plus the 5400 flange has made me use a 2” adapter to a 4150 carb
Now I have to run a drop base air cleaner bottom.
-peter
-peter
Chad, the goals are about the same as I have. Not really looking for more power. 623/626 is fine by me.(with old heads)
I was just trying to get a package that will survive and be more stable than I felt the last heads were.
Plus trying to get something together to prepare for the RR block build that eventually come.
It will be interesting to see if I pick up any though.
10.75 is my best. 10.5x would be nice!
Flemming...I really do think it needs a bit more CFM...it's only 850 right now.
-but not crazy about the drivability of a dominator!
I like to cruise this thing!
-peter
-peter
ProStreet442@aol.com Frank will hook you up. He was trying to get me to get one, but I wanted EFI. Now that I got their junk sensors replaced, it actually works pretty well
