Aftermarket torque converter...
Old Apr 10, 2012 | 02:47 AM
Stevec's Avatar
Was toying with the idea of replacing the torque conv while the engine is out.
Was thinking of something like 2200-2400.
Any suggestions? tips? Recommendations?
Do I need a tranny cooler? Etc. Or should I Just keep running the stock one?
Thanks for any help..
Old Apr 10, 2012 | 03:00 AM
Stevec's Avatar
It's a 400 engine with a th400 and 3:55 gears. Cutlassefi hooked me up with a roller cam
Rh282/350 rh294/340 110+4 is the grind of the cam
Old Apr 10, 2012 | 07:01 AM
It sounds fine to me, I would see what cutlassefi recommends also. If it's just a weekend cruiser, you should be fine without one.
Old Apr 10, 2012 | 07:15 AM
455man's Avatar
I'd think a slight stall would help but check with cutlassefi. He knows your motor.
Old Apr 10, 2012 | 07:42 AM
gearheads78's Avatar
car guy
In a high performance application the torque converter is one on the most important selections you can make. It will truley make or break a combination. You should always run an extra cooler on the street with a stall converter. Its cheap insurance to help keep the temps down.
I know a lot of people are not going to agree with me but the generic converters most people use are inefficient junk. I learned myself the difference with a car. $179.00 cheapie converter and switched to a good ATI converter that cost me just under $450.00 (9 years ago) The car picked up 4 tenths at the track and was much more street friendly around town. Both were 2500-2800 11" converters.
The best thing to do is call one of the good converter companies and give them all the info about your car (you will need the duration @.050 numbers for that cam) and let them tell you what you need. I have had great luck with ATI but there are many others that make good converters.
Old Apr 10, 2012 | 08:32 AM
Stevec's Avatar
Thanks guys..
I apreciate the feedback..
Old Apr 10, 2012 | 10:14 AM
380 Racer's Avatar
X2 except I like Coan.
Old Apr 10, 2012 | 10:21 AM
coppercutlass's Avatar
Chevy budget Olds powered
I got a cheap one and it was a 10 in. advertised 2600-2800 and its closer to 3000 rpm it works good but if money allows I'm putting in a nice one or having mine redone locally. I ran a jegs 2300-2500 and it was the same as my tci 2000-2200 stall. The tci I used was the saturday night special it was good and the price didn't break the bank.
Old Apr 10, 2012 | 10:34 AM
car guy
I have also heard good things about Coan. I ran a Neal Chance in my race car but that was a $1200.00 converter last time I was in touch with the new owner he had it down in the 5.30's
Old Apr 14, 2012 | 02:51 PM
panos's Avatar
I have a 11" custom made from http://www.abruzziracing.com/main.html
Works like a charm
Old Apr 14, 2012 | 05:17 PM
ziff396's Avatar
I am running a Hughes 2500 on mine. Seems really nice for the street with the 455 moderate build, 3.42's. No slushy shifts at part throttle, and great response when hitting it.
Old Apr 14, 2012 | 06:59 PM
TripDeuces's Avatar
I had a cheap one balloon and wipe out my crank. Stick to the good stuff.
Old Apr 18, 2012 | 07:28 PM
SBORule's Avatar
X2
Especially with a BBO that makes a ton of torque. Get one with anti-balloon plates.
PTC makes good convertors too. Checkout their website, you might find their prices aren't too bad either.
Old Apr 19, 2012 | 09:17 PM
ah64pilot's Avatar
Do you guys know of anyone that makes a switch pitch these days? I was thinking PATC made one but I couldn't find one on their site for a TH400.
Old Apr 20, 2012 | 05:46 AM
TripDeuces's Avatar
I had Jim Burek at PAE rebuild my S/P converter a few years ago but heard he is no longer in business. Here's his number at the time 915 855-6009. I think Phoenix Transmission might still do some S/P stuff http://www.phoenixtrans.com/IntlHome.html and possibly even Dacco http://www.daccoinc.com/. Here is PATC url also http://www.transmissioncenter.net/
All it takes is a phone call to find out.
P.A.E Enterprises, Inc.
4401 Turf Rd. Bldg E
El Paso, TX. 79938
915.855.6009
915.857.4727 -> Tech Line 8-10am and 4-5pm MST M-F
www.paeenterprises.com
Found this too but I doubt it will be much help, sorry
67Olds442X2
Sep 6, 2011 06:12 AM
scrappie
Apr 3, 2008 06:41 PM
Fred H
Jan 24, 2008 07:58 PM
SPEEDROCKET
Dec 18, 2007 06:35 PM
Surfrat67
May 14, 2006 03:42 PM
