69 442 race car build
Old Jan 7, 2016 | 04:04 AM
  #161
Milan..'s Avatar
Great pics Chad....!
Old Aug 11, 2020 | 05:55 PM
  #162
chadman's Avatar
Well it's been awhile since I've posted and a lot has changed since then. Hoping to have this thing track ready before long now.
Old Aug 11, 2020 | 06:42 PM
  #163
Bernhard's Avatar
Very Nice! Ultra clean build!
TOP SHELF!
Old Aug 11, 2020 | 07:09 PM
  #164
oldsmoboogie's Avatar
That looks amazing! I love that color. What wheels are those?
Old Aug 11, 2020 | 08:32 PM
  #165
chadman's Avatar
Thank you. The wheels are Champion Racing. They are unfortunately no longer in business. These are for sale though. I have other plans as far as wheels go.
Old Aug 11, 2020 | 08:38 PM
  #166
Battenrunner's Avatar
Ok Chadman, I am officially jealous!
That is one mean, clean, racing machine!
What is your engine combo and output; transmission; rearend?
Weight of the car?
Goals for the car, etc.?
Old Aug 11, 2020 | 08:39 PM
  #167
chadman's Avatar
I love that color.
I call it Busch Light Blue. LOL
Old Aug 12, 2020 | 07:25 AM
  #168
chadman's Avatar
Weight of the car?
The engine is 462 CID. 4.185 x 4.200 stroke. Billet crank, full girdle, aluminum rods, Rocket Racing heads, solid roller cam. It makes 790hp at 7500 rpm. Trans us a built up th400. Rear is a Moser M9. Unsure of the weight but estimate 3250 with driver. Goal is 9.30s at over 140 mph.
Old Aug 12, 2020 | 08:19 AM
  #169
wr1970's Avatar
Awesome build great color.
Old Aug 12, 2020 | 08:28 AM
  #170
69455's Avatar
Dam nice ride !!
Old Aug 12, 2020 | 10:57 AM
  #171
Bernhard's Avatar
It would be nice to see your car featured and get the ink it deserves. How many hours do you think you have into the build?
Old Aug 12, 2020 | 12:29 PM
  #172
DENT's Avatar
How did you mount the front of your engine?
Old Aug 12, 2020 | 01:02 PM
  #173
chadman's Avatar
Thanks for the kind words. I couldn't even begin to estimate the amount of hours I have in this thing.
Old Aug 12, 2020 | 01:19 PM
  #174
64Rocket's Avatar
Super nice !!!
How did you mount the steering shaft down to the rack and pinion? I can't see the shaft or actually the steering wheel.
Gene
Old Aug 12, 2020 | 01:31 PM
  #175
chadman's Avatar
Originally Posted by 64Rocket
Super nice !!!
Gene
It's not currently in the car. I will post pics when I get it back in. Headers need to go in first and they are currently at the coater.
Old Aug 12, 2020 | 01:50 PM
  #176
chadman's Avatar
It's mounted with the aluminum plate you can see in the pics. It's bolted to tabs welded to the frame. There is another plate between the engine and transmission as well. There are no motor mounts on the sides of the block.
Old Aug 12, 2020 | 02:07 PM
  #177
Beautiful build.
Old Aug 12, 2020 | 02:29 PM
  #178
hotrod442's Avatar
That's one MEAN OLDS!
Old Aug 12, 2020 | 03:15 PM
  #179
RALLYE KID's Avatar
awesome !!!
Old Aug 12, 2020 | 04:20 PM
  #180
VORTECPRO's Avatar
Nice work!
Old Aug 12, 2020 | 10:10 PM
  #181
Very, Very nice.....
Would you mind sharing your cam specs/card and any pics or info you have for the heads(flow numbers, etc.)?
Compression? expected fuel you will run?
Converter info?
When and where do you plan to start doing some shakedown runs?
Thanks again for sharing your build; it truly does look magazine worthy.
Old Aug 12, 2020 | 10:26 PM
  #182
chadman's Avatar
Very, Very nice..... Thank you
Would you mind sharing your cam specs/card and any pics or info you have for the heads(flow numbers, etc.)? cam is around .750 lift and 269/275 @.050 heads flow 340/240, engine was built by Milan Obradovich
Compression? 12:1 expected fuel you will run? 112 Sunoco
Converter info? 8" 5500 stall
When and where do you plan to start doing some shakedown runs? within the next month. Dragway 42
Old Aug 13, 2020 | 03:43 AM
  #183
gear head's Avatar
Badass, I dig it!
Old Aug 13, 2020 | 06:04 AM
  #184
VORTECPRO's Avatar
"engine was built by Milan Obradovich"
Hold on..........thats a shocker, I would have thought you would have used the "Olds Expert" cutlas EFI, but then again after looking at the car build one would know better LOL.
1320/144 MPH = 9.16 @ 3250
Old Aug 13, 2020 | 07:52 AM
  #185
DENT's Avatar
My friend is building a car with the same mounting on his Olds 350 block , just wondering how the plate bolts to the block ?
Great looking build by the way ,
Old Aug 13, 2020 | 10:03 AM
  #186
Bernhard's Avatar
Are the bumpers going to be steel or glass?
Are your new wheels going to be of your own design?
Old Aug 13, 2020 | 10:56 AM
  #187
chadman's Avatar
Bumpers are glass. They are at the shop getting Cosmichrome now. The wheels will be a surprise, stay tuned.
Old Aug 13, 2020 | 01:42 PM
  #188
chadman's Avatar
Typically I build my own engines and also for a small group of customers but I couldn't pass up the opportunity on this one. It isn't every day that you get the chance to get your hands on an intake and a set of heads done by John Marcella. It's a proven performer and being built by Milan I know it was done with detail and no corners cut.
Old Aug 13, 2020 | 04:15 PM
  #189
RetroRanger's Avatar
72 Olds CS
Wow car looks great engine numbers look awesome.
Old Aug 13, 2020 | 06:30 PM
  #190
VORTECPRO's Avatar
I really like the 7500 RPM peak, more gear, more converter-things happen faster! What was the peak TQ?
Old Aug 13, 2020 | 07:39 PM
  #191
chadman's Avatar
Old Aug 13, 2020 | 08:14 PM
  #192
VORTECPRO's Avatar
Thanks for posting. If the trans and converter are as well thought out as that engine I could see much quicker than 9 teens. I always get a kick out of internet TQ talk, high RPM HP wins drag races-always.
Whats your gear stack in the trans and rear gear?
Old Aug 13, 2020 | 08:28 PM
  #193
chadman's Avatar
It's the stock 2.48/1.48/1.00 ratios and a 4.10 in the rear w/29.5x10.5 tire
Old Aug 13, 2020 | 08:37 PM
  #194
VORTECPRO's Avatar
Below
Old Aug 13, 2020 | 08:41 PM
  #195
VORTECPRO's Avatar
We have run cars similar to what you have, although the lightest one was 3400 and the heaviest being 3600. Both cars utilized a 2.30 first gear, and 30x10 radial slicks, I think a 4.30 gear would be a good starting point. I really believe you have a high 1 teen 60 foot car there with the right drive line behind that engine. Please let us know how your testing goes.
Old Aug 13, 2020 | 09:21 PM
  #196
That is a great looking dyno sheet, thanks again for posting your info/specs on things as well!
Old Aug 18, 2020 | 01:32 PM
  #197
chadman's Avatar
The spray chrome guy just sent me this. Hope to pick up the bumpers this weekend.
Old Aug 18, 2020 | 01:56 PM
  #198
64Rocket's Avatar
Bumpers
Are those fiber glass bumpers?
the pic looks awesome.
Old Aug 18, 2020 | 02:47 PM
  #199
chadman's Avatar
Yes they are fiberglass.
Old Aug 18, 2020 | 05:29 PM
  #200
Bernhard's Avatar
WOW The spray chrome looks amazing
