455 Milodon Windage Tray
I searched and did not find direct answers to questions below but only conflicting info. I posted this in the racing and just assumed people have more experience with this here:
1. Does a windage tray in a 455 with standard volume pump help control oil flow back into the pan better (as opposed to not having one)?
2. Does the block need to be lined honed with the Milodon studs installed? 81219 kit comes with 4 studs for 2 mains.
3. Is a windage overkill for a street motor?
Thanks in advance!
Thanks in advance!
2. In my OPINION from my EXPERIENCES if you already have studs you should be able to install without any issues. If you have bolts I would install, torque and measure. If it comes up out of spec you need to fix. I have heard of guys just throwing them in without any issues but can' not confirm.
3. In my OPINION from my EXPERIENCES anything you can do to help oil control in a performance application is always a plus.
In my OPINION from my EXPERIENCES as far as the effectiveness of the Milodon unit I have no hard data. I have used it with no ill effect. From my EXPERIENCES the one from Mondello is prone to cracking.
I haven't bought anything from Mondello Performance since Joe sold the place so I can't comment on the current products. I have bought from Bernard in the last two years. I received exactly what I ordered.
1. In my OPINION from my EXPERIENCES a properly designed windage tray should help oil return. The oil pan can have direct impact on how well it works. The job of the tray is to isolate the rotating assembly windage from the pan.
