455 crank in a D/DX block
Okay orange 442 started a thread on ROP. So i thought why don't we discuss it here also. Can a 455 steel crank be modified for a D/DX block? My thinking is yes and the cast crank as well!
Oldsmobile dave claim he has a 4.30 stoke crank in a D diesel block if i have my info correct! Mark cutlassefi can anyone install a 425 crank in D/DX diesel block with out modifying the crank!Answer NO! So that is why i said modify a 455 crank! You should elaborate more on why you ask the question about modifying 455 crank to fit. Please weigh in on this discussion because those who read this thread may learn something. I am sure i will i hope.
On any crank with a 4.300 stroke you'll need to cut the counterweights for piston clearance and cut the journals as well. You only have so much deck height so with the 4.300 stroke and the shortest BBC rod available you're still looking at a piston height of about 1.030. The wrist pin will be in the ring pack, why? Imo this is unnecessary.
You could use a SBC rod instead but you may run into an oil hole problem with it moving too far towards the radius. Plus I don't like to see such a short rod to stroke ratio. That's hard on the cyl walls.
Jmo.
Jmo.
Jmo.
Jmo.
In order to use a 4.300 stroke and still have a usable c.h. piston you would be using a 6.125 sb rod or 6.135 bb rod. In order to make a rod and piston combo physically clear the crank counterweights you would have to take the counterweights down to a smaller diameter than what is normally done. You would have to get a second mortgage on your house to be able to afford enough Mallory to even try to balance it. I personally don't think that is something I would want to try. I would build a 4.00 stroke 6.25 rod 1.062 c.h. piston combo. Set the bore size to 4.155 and you have a nice 434.
Yes the balance is done with Bob weights that equal components connected to the crank. My point is by the time you reduce the cranks counter weights enough to clear the short rod combo that long stroke requires the common connecting rods and pistons available will give a Bob weight greater than the counterweight of the crankshaft. In reference the common 4.00 stroke combo using common BBC rods usually requires at least 4 slugs of Mallory to internal balance from what I have found.
ut442
March 9th, 2012 11:57 AM
J-(Chicago)
November 30th, 2010 02:25 PM
sx455raidercelticfan
November 23rd, 2010 05:45 AM
