3201 hookers
Old Sep 24, 2012 | 07:09 PM
jfb's Avatar
jfb
Exclamation 3201 hookers
HEY GUYS HERE IS A QUESTION THAT CAN ONLY BE ANSWERED BY SOMEONE WHO HAS HAD THIS POSSIBLY HAPPEN. i HAVE 1 TUBE ON THE DRIVERS SIDE OVER THE FRAME BY MEASUREMENT IT FITS. THE PROBLEM IS WILL A 235 60 TIRE GROW BY BF GOODRICH BY THE WAY AND POSSIBLY UPON TURNING ETC CONTACT THAT TUBE. THE SPRINGS ARE STIFF AND I HAVE KYB SHOCKS BUT LOWERED ONE HALF INCH OVERALL.
Old Sep 24, 2012 | 07:16 PM
70Wcars's Avatar
Your clearance will depend on wheel back-space. I run that Header, but with M/T drag fronts on 4" Welds. Most probably when you make a hard left turn so that the back of the wheel/tire is closest to the Header tube that 60 series tire will be verrrry close.
Sorry i haven't experience with a wider tire.
Danny
Old Sep 24, 2012 | 07:27 PM
jfb's Avatar
jfb
These wheels are not back space the rims go out.
Old Sep 24, 2012 | 08:11 PM
ihengineer76's Avatar
So you are saying the surface that bolts to the hub is even with the edge of the rim?
Old Sep 25, 2012 | 12:37 PM
jfb's Avatar
jfb
yes the center section is even with the hub, I seriously hope that someone has had experience with these headers on the street and most of the time unless using nitrous i drive to the track. I do not want to find out on a long trip if i am going to have trouble so far with regular driving there seems to be no problems but you never know until it is to late with my luck.
Old Sep 26, 2012 | 06:44 PM
jfb's Avatar
jfb
hey 70wcars i have 1 more question for you on those headers. I lifted the brake lines for more air circulation but have you had any heat problems with your brake lines at all along the frame. jfb.
Old Sep 27, 2012 | 07:53 AM
ALL wheels have backspacing. That is simply the measurement from the inner lip of the rim to the wheel mounting flange.
Old Sep 27, 2012 | 12:23 PM
jfb's Avatar
jfb
thanks for the correction joe i always thought of rims as reversed or totally back spaced.
Old Sep 27, 2012 | 02:01 PM
70Wcars's Avatar
Nope, but my car is a strip only car so not much time for heat to build up. I just unbolted the Proportioning valve from the frame then bent the lines enough to give me air space between the Header and the Brake stuff. Didn't even re-bolt the Valve to the Frame, just let the brake lines suspend it. No issues in 6 years like this.
Danny
Old Sep 27, 2012 | 02:54 PM
jfb's Avatar
jfb
thanks for the info i bent the lines carefully when i installed the headers and lifted them above the tube for air flow the i put header gauze over the lines close to the tube this new combo will be a real shot in the a-- so to speak.
Guttermouth
Apr 25, 2013 07:26 AM
