3 angle valve job - blend in bottom cut?
Old December 12th, 2022 | 04:40 PM
RocketV8's Avatar
I just got my #2 heads back from the cylinder head shop. The valves are 2.07/1.71 with a valve/throat ratio of 88.5%. This made the bottom 60 degree cut wide with a sharp edge at the short turn.
Should I blend the bottom cut into the throat? Or just break the edge?
Should I do it all the way around or just the part marked in yellow?
Or just leave it?
Old December 12th, 2022 | 05:00 PM
cutlassefi's Avatar
Break the edge at least. These are going on a 330?
Old December 13th, 2022 | 03:19 AM
RocketV8's Avatar
Yes, but 340 cid (4" bore). It will have your cam in it.
/ Karl-Anders
Mora, Sweden
Old December 13th, 2022 | 06:05 AM
cutlassefi's Avatar
/ Karl-Anders
Mora, Sweden
Gotcha. Not sure I would’ve put such a large exhaust valve in it though.
Best of luck in your project moving forward.
Old December 13th, 2022 | 07:30 AM
RocketV8's Avatar
Yeah, I know it is an unnecessarily big exhaust valve. I bought them as a package deal years ago, so it is what it is...
Thanks!
1970_442
August 11th, 2018 08:50 AM
Eightbanger
September 12th, 2016 02:47 AM
69ishHoliday
December 9th, 2013 09:18 AM
oldsy
August 24th, 2013 01:56 PM
cts-v
February 25th, 2009 03:32 AM
Quick Reply: 3 angle valve job - blend in bottom cut?
