66/67 Cutlass V8 Engine Cooling parts
Old Sep 12, 2015 | 05:19 PM
66olds4dr's Avatar
Hi,
I am looking for some parts to install the Engine Cooling Equipment option on my car. I looked up all the part numbers from the Oldsmobile parts catalog. They were used on a 1966 Cutlass or 1967 Cutlass V-8 engine.
Clutch Fan (needs to be working and good condition)
P/N: 391191
6 blade fan
P/N: 391094
Water pump hub
P/N: 399394
55 Amp Delcotron with Pulley (needs to be working and good condition)
P/N : 1100730
Power steering pump pulley (1 Groove)
P/N: 384678
Water pump pulley (3 Groove)
P/N: 391114 or 391433
Crankshaft pulley (3 Groove)
P/N: 389645 or 391434
Old Sep 13, 2015 | 08:01 AM
Roger60's Avatar
I have the water pump pulley 391114. $25. + ship
Old Sep 13, 2015 | 01:34 PM
lemoldsnut's Avatar
I can more than likely do the pulleys all three of them. Will check. I am assuming this is an AC car right?
Old Sep 14, 2015 | 09:28 AM
66-3X2 442's Avatar
Originally Posted by 66olds4dr
Hi,
P/N: 391191
6 blade fan
P/N: 391094
Water pump hub
P/N: 399394
P/N : 1100730
P/N: 384678
The alternator should be part # 1100733 55 amp. I do have one if you still need it. I should also have the fan. Contact me @ pchopesq@aol.com
Old Sep 14, 2015 | 10:02 AM
Octania's Avatar
I have pulleys, probably
Old Sep 23, 2015 | 05:41 PM
lemoldsnut's Avatar
I have the pulleys for sure.
391434
399404
384678
If you are still looking let me know
Larry
lemoldsnut@aol.com
5998DownUnder
Feb 2, 2014 02:40 AM
69CutlassAlex
May 31, 2012 07:05 AM
pcard
Jan 20, 2012 06:43 PM
balage
Aug 8, 2010 08:16 AM
68conv455
May 12, 2008 05:29 PM
