Wanted olds 12 bolt 2.93 gears
Old Aug 19, 2014 | 12:44 PM
gevosrears's Avatar
WANTED TO BUY OLDS 12 BOLT 2.93 GEAR SET . ( 10 BOLTS ON RING GEAR ) Call John , 315-568-9744
Old Aug 19, 2014 | 02:47 PM
oldsmobiledave's Avatar
2.93
Never seen Type O gear sets in this ratio and 99.9% sure that they do not exist.
Old Aug 19, 2014 | 03:06 PM
Octania's Avatar
2.73:1 is pretty close though
I had a posi with that gearset, 68-9 issue I think, type O ?
You might need to specify the year of issue to get the right gearset.
Old Aug 19, 2014 | 03:45 PM
orange442's Avatar
I believe 2.56, 2.78, and 3.08 are the only gears the O type 12 bolt had that is close to what you are asking for. The 8.5 10 bolt has the 2.93 or something close to that. That is what the code was on the inside trunk tag of my 84 Caprice 2 door that originally was a diesel. It is an 8.5 rear and also has the G80 posi code as well.
Old Aug 19, 2014 | 04:08 PM
gevosrears's Avatar
2.93
I guess that`s why I can`t find any ! Thanks for the info .
Old Aug 19, 2014 | 04:14 PM
orange442's Avatar
GU3 RPO code: 2.93 8.5 10 bolt. Looked it up again to make sure.
Old Aug 19, 2014 | 08:26 PM
olds3442's Avatar
I have one out of a 69 cutlass that's a 256 non posi drum to drum in Dayton ohio 175.00
Old Aug 19, 2014 | 11:20 PM
orange442's Avatar
Also found this ratio in 69 service manual for big cars only.
joesw31
Apr 14, 2015 07:56 PM
boc23
Drivetrain/Differentials
Aug 29, 2014 02:23 PM
monzaz
Aug 7, 2014 11:12 AM
monzaz
May 29, 2010 08:46 PM
cranesperformance
Aug 5, 2009 02:29 PM
