68 Dash Pad and parts needed Cutlass S
Old Jul 5, 2014 | 07:18 AM
Xlhowie's Avatar
I am semi restoring a 68 Cutlass S and need the mounting hardware for the gages, black glovebox, and dash pad. I just cut out a whole bunch of welded in body work on the dash and I am wanting to install a stock dash. I have the dash face plate. Please look at pics. Let me know everything I'll need. thx, Howie
I have included the current pic and an old pic (tin not cut out)
Old Jul 5, 2014 | 07:35 AM
Looks like you need everything. FYI 68/69 dashes are the same so you can use either for donor parts. Like the 70-72 models there is no difference in the dashes between trim/models, although I believe non AC cars don't have all the vents.
Old Jul 5, 2014 | 08:02 AM
Xlhowie's Avatar
Thx Allan
How much of the metal is actually exposed? I have to do a lot of sanding and smoothing to repaint where I had to cut it. I dont want to do it if it is under the dash or pad. Thx, Howie
Old Jul 5, 2014 | 09:23 AM
Olds24's Avatar
Almost, 68 has Ignition switch in Dash 69 does not.
Old Jul 5, 2014 | 09:41 AM
dnmfranco's Avatar
have black glove box which are different from 69 as well as lower dash
dash pad will check, far as 68 ONE YEAR dash ONLY if non a/c
pretty sure on gauges mounting parts
Old Jul 5, 2014 | 12:49 PM
Ah yes, 69 was the year they went to the ignition on the steering column.
Xlhowie: you can see how little metal is actually exposed in these shots. How much of a 'semi restoration' are you doing? I guess to me the bottom line would be if you wanted the stock look for the year. Dash pads are really easy to color change.
The dash pad for 68/69 is different if the car is AC or non AC. I'm curious what differences the lower dash has - other than trim and ignition switch? Note: All Cutlass models equipped with wing windows and non AC from 68 - 72 did not have vents in the dash pad. This may be true for earlier models too, but I'd have to check and verify that.
Here are 2 pics of 68/69 dashes. The first one - 1968 without AC
Note ignition in dash to right of heater controls. Looks like the other switches and controls are in the same place, just different trim *****.
1969 - without AC - note heater plate and lower vent pulls.
Old Jul 6, 2014 | 05:30 AM
goldie442's Avatar
good morning...i have some pristine 68 dash parts (black) including the glove box lid..if you are interested please send me your email address and i will send you pics of what i have and we can go from there..my email address is: sixtiesclassics@live.com
Old Jul 10, 2014 | 02:33 PM
Xlhowie's Avatar
goldie sent pm to you
I sent you a pm about the parts. My yahoo is giving me fits. Can you email me at xlhowie@yahoo.com
Thanx, Howie
Bryan59EC
Jun 3, 2010 10:36 AM
floater98
May 27, 2010 03:45 AM
BigWelder036
Apr 29, 2010 07:40 AM
5636Randy
May 3, 2009 09:59 AM
DJMatthews
Dec 12, 2006 06:36 AM
