68 glovebox lock
Old May 30, 2014 | 11:53 AM
'69CutlassVert''s Avatar
68 glovebox lock
Need one
Old May 30, 2014 | 12:40 PM
jensenracing77's Avatar
I have one out of a 69 H/O but I don't have a key. I can't remember how to get them out of the lid. I will look it up and see if i can do it without the key? If I can get it out, how about $20 shipped.
Old May 30, 2014 | 05:35 PM
501Paratrooper's Avatar
Jensen, it takes a special tool, but I was able to put one handle end of a pair of pliers with a rubber grip and twist and mine came out.
Old May 31, 2014 | 06:53 AM
Oddly enough my 69 is an early run with a 68 lock. Is yours a push button or a twist handle
Old May 31, 2014 | 06:55 AM
If it's a push button then yes 20 is great thanks
Old May 31, 2014 | 07:23 AM
It is push button but i can't figure out how to get the lock assembly out of it.
Old May 31, 2014 | 01:31 PM
Either sale the whole door, or I'll remove the lock and return the door to you?
Old May 31, 2014 | 02:14 PM
Octania's Avatar
I have been able to remove the nut/ escutcheon by applying a continuous CCW force to it while wiggling the lock backside CW/CCW. Each tiny bit of movement gets you a little more nut motion, and pretty soon it is loose enough to come right out.
You are supposed to depress the tang that you can almost see, lock side, thru that tiny hole, then insert the [or any] key to hold that tang down. Then the lock cyl will slip right out. This is supposed to be done with THE key, and possibly in the locked position.
If you don't have THE key then try the finger method to remove the nut.
Or, copy the code off your trunk cylinder or console cylinder and any locksmith can make a key.
I have the key code book if it comes to that.
Old May 31, 2014 | 03:52 PM
So you're the keymaster?
I have the key code book if it comes to that.[/QUOTE]
Jandk
Ninety-Eight
Apr 17, 2015 12:20 AM
507OLDS
May 5, 2011 04:10 AM
dyscookn
Jun 11, 2010 05:42 AM
mauls
Jun 3, 2010 07:40 PM
fallsguy
Jan 13, 2007 05:48 PM
