Wanted..3:42 gears for 8.2
Old Feb 7, 2014 | 10:13 PM
Big Leche's Avatar
Let me know if you know anyone that is willing to sell a set..
Old Feb 7, 2014 | 11:17 PM
4speed455's Avatar
I have a used set of 3.36 gears for a 8.2 I could let go for $100 plus shipping. Let me know, thanks Joel.
Old Feb 8, 2014 | 07:51 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
8.2 wasn't available with 3.42 gears.
goes from 3.36 to 3.55 I believe.
Old Feb 8, 2014 | 09:06 AM
4speed455's Avatar
My 3.36 gears are for a BOP 8.2. I believe the chevy 8.2 came with 3.42 gears. Which rear do you need gears for?
Old Feb 8, 2014 | 09:10 AM
1970supremevert's Avatar
pm sent
Old Feb 8, 2014 | 06:04 PM
Big Leche's Avatar
Gears
This just gets better and better....youre telling me that the chevy and BOP 8.2 are different?
Old Feb 9, 2014 | 09:39 AM
Not only that.......A Buick 8.2 is different than a pontiac 8.2, which is different than a Chevy 8.2. And 68-72 are different than 64-67 sometimes.
BUICK 68-70
Ring Gear Diameter 8.2 'B' Buick SKYLARK AND GS ONLY
Cover 1385724, 1382700
Cover Bolt Count 10
Ring gear Bolt count 10
Ring Gear Bolt Size
7/16 left hand thread 3/4 socket head bolt is left hand thread
Axle Spline 28 bolt in axle 60 degree spline
Yoke style U bolt & nut Universal joint retention
Pinion Spline 27
Carrier breaks 2.56 / 2.73-2.93 / 3.23-3.42 / 3.64- up
Pinion Diameter 1.875 <<<<<<< CAN NOT USED AFTERMARKET 8.2 GEARS!!!!!
Axle Shaft Diameter 1.382 press on bearing
PONTIAC
Ring Gear Diameter 8.2 P. Pontiac HOUSING (DIAGONAL WEBBING) (tempest)
Cover Bolt Count 10
Ring Gear Bolt Size 7/16 left hand thread TIP3/4 socket head bolt is left hand thread)
Yoke style U bolt & nut Universal joint retention (reference picture)
Pinion Spline 27
Carrier Breaks 2.56-2.78 / 2.93-3.23 / 3.36-4.33 and up
Pinion Diameter 1.438 <<<<<< 8.2 after market gears WILL FIT these housings
OLDS and BUICK
64-67
B.O.P. Buick/ Olds (single lower webbing)
Pontiac (diagonal upper webbing and lower webbing)
Cover Bolt Count 10
Ring Gear Bolt Size 3/8 Fine Right Hand Thread (11/16 socket headed bolt)
Pinion Spline 27
Carrier Ratio Breaks 2.56-2.78 / 2.93-3.23 / 3.36- 4.33 and up
Pinion Diameter 1.438 <<<<<< AFTERMARKET 8.2 GEARS WILL FIT THESE HOUSINGS
CHEVY
Ring Gear Diameter 8.125 AKA Chevy 8.2
Cover Bolt Count 10
Ring Gear Bolt Count 10
Carrier Ratio Break 2.56- 2.73 / 3.08 - 4.56 and up
Axle Spline 28 C-clip 45 degree splines
Pinion Spline 25
Axle Shaft Diameter 1.400
boc23
Drivetrain/Differentials
Aug 29, 2014 02:23 PM
monzaz
Aug 7, 2014 11:12 AM
monzaz
May 29, 2010 08:46 PM
idaholc
Apr 13, 2009 01:33 PM
bbolds442
Mar 27, 2008 12:35 PM
