1966 400 E-Block - Want to Buy
Old Nov 18, 2013 | 09:07 AM
Timmy1966_442's Avatar
Looking for a 1966 Dated E-Block 400 with Crank and pistons preferred. Good rebuildable or running condition. Send me a PM if you have one you are looking to sell.
Thank you,
Tim, Sacramento CA
Old Nov 18, 2013 | 09:41 AM
wmachine's Avatar
Trying to remember member
Thank you,
Tim, Sacramento CA
Have you figured out how to tell if a 400 E is '66 or '67?
Old Nov 18, 2013 | 01:09 PM
That's a good question, I assumed it would have the Make-Year-Factory-Vin derivative stamped driver's side front like my 455. If not I suppose the correct casting would be enough
Old Nov 18, 2013 | 01:13 PM
This is what I was thinking...
Pre 1968 engines also had an engine unit number stamped on to the machined pad at the front of the RH head. I believe that the Toronado 425's started with a T rather than a V.
V 001001 1965 400 442'sV 100001 1966 400 442'sV 200001 G 1967 400 4V 442's, including W-30V 200002 1967 400 2V 442's, [etc.?] Turnpike Cruiser
Old Nov 18, 2013 | 01:23 PM
wmachine's Avatar
Right, but that number is on the head, not the block. So that won't do you any good with a short block or less. The block has an ordinal date code, but it is only for the day of the year, not what year. The 400E blocks are the same, though.
Pre-'68s did not have the VIN derivative as I expect you've found out.
Old Nov 18, 2013 | 02:40 PM
I should have looked harder at what I have sitting. I have the original heads, so I am in business. Thank you for the input.
Old Nov 19, 2013 | 06:28 AM
Run to Rund's Avatar
I have a few E blocks.
Liegekiller
15
Jun 27, 2009 07:58 PM
Liegekiller
May 30, 2009 05:31 PM
1960es
May 7, 2009 06:05 PM
MWS88Dynamic
Jan 16, 2007 12:40 PM
