Reservoir's & pulley
Old Jun 27, 2013 | 10:06 AM
rcrac3r's Avatar
I'm looking for the coolant & washer fluid reservoirs for a 1972 Cutlass. Also looking for a water pump pulley with 3 grooves. The 2 groove I have, the second groove lines up perfect for the water pump, but I need a 3rd groove for my alternator. I don't have A/C.
Old Jun 27, 2013 | 09:03 PM
2blu442's Avatar
There's more than one three groove pulley for the water pump. If you would get the two letter codes off the crankshaft and power steering pulleys we can key out the one you need. John
Old Jun 28, 2013 | 08:04 AM
rcrac3r's Avatar
Ok. The other thing I've found out is the PO replaced the water pump, & it is physically longer than the original by about an inch. Napa, Auto Value, etc all show the same pump for a 1972 Cutlass w/350 no A/C & it is longer than the original. The pulley I have is off of the original pump, it has "KN" on the front of it. The pic shows the measurement & if I could find one that measured 3" from the base of the pump to the back of the 3rd groove that would do it.
Old Jun 29, 2013 | 05:29 AM
ROCKETMAN269V's Avatar
There is a chance that someone replaced the engine along the way. '68-'70 pumps are the same for a given application and '71-up are different from the earlier ones. Check the # on the front of the driver's side cylinder head, next to the front head bolt. '72 should be a 7a. Just a thought.
Old Jun 29, 2013 | 06:58 PM
rcrac3r's Avatar
I do know for sure that the engine is the original. The heads have the "7a" on them as well.
Old Jun 29, 2013 | 07:13 PM
Octania's Avatar
KN is 7.3 diameter x 2.07 overall width
W3 [Water Pump, 3 groove] pulleys with width about 2.7" would include
JI from a '67 330; spacing will differ a little between an end groove and the other 2
JH from a '67 425, same spacing diff.
KF from a '70 wit AC
LD from the smog era engines
The best way is to put the proper length WP back in place with the proper pulley.
It should not be that hard to find the correct length WP.
The 2nd best method would be to read the ID code on your crank pulley, bring that info here, and we can then figure out what WP pulleys, if any, will fit right-ish. I have a mockup V8 I can test fit pulleys on. And a good stash of used pulleys.
Colorado Olds
Brakes/Hydraulic Systems
17
Jul 21, 2009 08:17 PM
ztim
22
Jun 29, 2008 05:13 AM
Pfiffle
Apr 8, 2008 06:49 PM
roamer
Apr 6, 2008 07:13 PM
