Wtb '70 dash lamp housings and pin switch lead
Old Jun 11, 2013 | 08:26 AM
ROCKET VAPOR's Avatar
Lance
Looking to buy the below items for a '70. I am hoping that someone will have a courtesy lamp equipped dash that they are using for parts. Also a dash wiring harness that is being used for parts.
1. Pin switch connector and leads for passenger side door jamb pin switch. Connector is cylindrical white plastic with two of the three holes containing silver pins. Leads are one white and the other is white with a black tracer stripe. Would like the leads at least 12” in length.
2. Courtesy lamp housing for headlamp switch. This zinc plated metal lamp housing has a ring that attaches to the front of the headlamp switch to illuminate the “lights” plaque above the switch’s pull ****.
3. Courtesy lamp housing for the ash tray. This zinc plated metal lamp housing is riveted to the back side of the plastic dash carrier behind the ash tray well thru a grounding strap/ band.
4. Dash courtesy dual lamp flood light housing and blue rectangle lens. This black louvered metal dual lamp housing is located above the AC/ Heater controls. Would like the whole assembly if possible (dual lamp housing, blue rectangle lens, and all attaching hardware).
Thank you in advance for your help!
Old Jun 11, 2013 | 10:11 AM
oldspackrat's Avatar
I have all those parts, how about $35.00 shipped for everything?
Scott
c. 317-727-7041
Old Jun 11, 2013 | 10:17 AM
Lance
Scott, you have a deal. Please let me know how you would like your funds. Thank you for your help!
hurst68olds
Sep 16, 2014 06:41 PM
eddieunderground
Jul 16, 2013 02:37 PM
Al Graaf
Nov 8, 2012 06:30 AM
stlbluesbrother
Apr 13, 2012 12:56 PM
oldspackrat
Dec 13, 2011 07:08 PM
