69 Cutlass 350 exaust manifold
Old Feb 16, 2013 | 03:06 PM
Ceilingman's Avatar
needing a 69 350 exhaust manifold for a cutlass it is the cross over manifold looks like this
Old Feb 16, 2013 | 03:26 PM
jensenracing77's Avatar
You want the right side (passenger)? I have them in average condition. $15+shipping. Where are you located? If i am far away you may find someone closer and save some shipping.
Old Feb 16, 2013 | 03:50 PM
Ceilingman's Avatar
I'm located in Nebraska yes it is the passenger side let me know how much shipping will be I'll take it would you have the driver side one also
Old Feb 16, 2013 | 04:07 PM
I have the driver side but from a 70-72. They are the same but i think the original 69 had a flapper plate in the outlet. If you are not worried about the flapper this would be the same other than that. Also $15. $30 total+ shipping. I will have to look up what shipping will be.
Old Feb 16, 2013 | 04:11 PM
Ceilingman's Avatar
Ill take both thank you shipping address
Carl Schroer
1908 E 34th st
Kearney, NE 68847
Old Feb 16, 2013 | 05:23 PM
I just went out and got them out. the driver side has a broken bolt. I will try to get them out Monday at work. I have another driver side that is real nice but it is a little newer. It would fit and function the same but has a slight differant look. I will get pictures for you after i get the bolt out or if you want the newer one i could get pictures in the morning.
Old Feb 16, 2013 | 06:08 PM
Ceilingman's Avatar
If you could get the bolt out that would be great
Old Feb 20, 2013 | 04:22 PM
Ceilingman's Avatar
just wandering if you had any luck getting the bolt out
Old Feb 20, 2013 | 05:10 PM
We were out of acetylene till today. Unfortunately i was not able to get them out. They are broken off worse than they were. They will need drilled out. You may be better finding another set. I don't have time right now to work on them more. There should be several guys here that have them. I have a near mint set but they are much more money. I don't mention them to often because i want $150 for them.
Old Feb 21, 2013 | 05:26 AM
ROCKETMAN269V's Avatar
Smile 69 Cutlass 350 exhaust manifold
I have some down here in sunny south Florida. E-mail me for pics, etc: drolds1@bellsouth.net. Thanks, Bob.
Old Feb 21, 2013 | 06:26 AM
Ceilingman's Avatar
Do yo still have the pass side that's the one I need the most
Old Feb 24, 2013 | 05:03 AM
Ceilingman's Avatar
Jensenracing Are you still wanting to sell just the passenger side manifold that's the one I really need
Old Feb 24, 2013 | 05:50 AM
Olds442redberet's Avatar
I had the same issue two months back.
I bought one passenger side manifold off ebay. I really needed it at the time so I paid $126.00 plus shipping. Then I paid $40.00 to have it planned / surfaced and the bolts taken out. It is media blasted and has new studs with brass bolts.
At the same time I bought a set of Thornton reproduction manifolds. I used the Thorntons and therefore still have the stock manifold. Give me a PM if you are interested.
Old Feb 24, 2013 | 05:59 AM
Sorry for missing the last post. It would be best to get one from the other guys. My passenger side had a block off plats and i broke the bolts trying to get it off. I have always had good luck getting them out with a torch but not this time.
Old Feb 24, 2013 | 03:54 PM
Check out the reproduction manifolds.
Old Feb 24, 2013 | 04:38 PM
65B01Delta's Avatar
I have a set of 69 350 exhaust manifolds that are Hurricane Katrina survivor's... The were stored in the attic, so they remained high & dry even though there was 10 feet of water below. If interested, PM with your email address & I'll send a few pictures.
Old Feb 24, 2013 | 05:04 PM
Here are a few pictures of the fruits of my labor. In the end I put on a pair of reproduction manifolds I bought off ebay for what this one manifold cost to buy, ship, surface, and put new studs in it. Now it sits on a shelf in a plastic bag so it doesn't flash rust on me.
rmoths
Sep 15, 2013 01:51 PM
Bluemeanie
Apr 17, 2012 08:06 AM
tomcat74cutlass
May 6, 2010 02:25 PM
mutt
Jun 11, 2009 02:47 PM
63 F85 Cutlass
Dec 28, 2008 07:18 PM
