Help! Need G-body rear control arm bolts
Old October 13th, 2012, 02:42 PM
Intragration's Avatar
Anybody local have a few rear control arm bolts and nuts available quickly? I snapped one and I'm in the middle of the project. Thanks.
Intragration is offline
Old October 14th, 2012, 09:02 AM
Run to Rund's Avatar
If one snapped, was it overtorqued or tightened with an impact gun in the past? If so, al may be subject to failure and should be replaced. If you use non-stock bolts, be sure they are the same or higher grade (10.9 or 12.9 is probably stock--look at the heads.)
Run to Rund is offline
Old October 14th, 2012, 09:10 AM
Chevy budget Olds powered
coppercutlass's Avatar
I broke all of mine when i replaced all my bushings. You can just go to the local ace hardware and find em which is what i did . No issues 3 years later.
coppercutlass is offline
Old October 14th, 2012, 10:12 AM
Thanks guys. The one that snapped was over-torqued upon removal haha. My torque wrench is longer than my breaker bar, and one nut was so tight I had to use it. It was clicking when I had it set to 120 ft/lbs, so I upped it to 150. It only clicked one more time, when the nut snapped clean off. I did check the hardware store, they had shorter bolts and non-locking nuts, but I'd prefer to use OEM stuff. I found GM may still carry them, PN 11502603 for the bolts and PN 11516073 for the nuts.
nolabigdawg
October 25th, 2014 11:50 AM
Oldssupreme
February 6th, 2013 12:39 AM
oldzy
December 17th, 2010 10:37 PM
henryk8398
August 14th, 2010 09:59 PM
J-(Chicago)
February 5th, 2009 05:05 PM
Quick Reply: Help! Need G-body rear control arm bolts
