Wanted: 72 Cutlass th350 Detent Cable
Old Aug 30, 2012 | 08:09 PM
Tony72Cutlass'S''s Avatar
Hi All,
I'm still working on my detent cable issue. I thought i'd see if anyone has a spare to sell in case i can't fix mine.
I need a 1972 Cutlass detent cable that goes to the TH350 (the kind that mounts to the accelerator pedal inside the cabin).
Thanks,
Tony
Old Aug 30, 2012 | 08:28 PM
Octania's Avatar
I have that PN
but it's after 11pm now
maybe tomorrow
Old Aug 31, 2012 | 04:14 AM
Octania's Avatar
17364
CABLE, KickdownCable TH350 to firewall, 1971 1972 Cutlass
NAPA part number ATP364 detent cable 1969-72 Cutlass
411340
CABLE, downshift or detent, 69-72 F85 TH350
4210
CABLE, downshift or detent, 69-72 F85 TH350.
Cable runs to FIREWALL and GAS PEDAL; Also on box from Advance Auto:
015-3841-6, 91-32-107254414, SKU=3925188, Barcode 51784
Crossovers: CA-1950, Y-104 [Made in Israel]
http://shop.advanceautoparts.com/buy...on-cables.html
Old Aug 31, 2012 | 05:43 AM
Originally Posted by Octania
4210
THATS AMAZING!
I have an advance auto parts about 45 minutes away in Champlain, NY. And it's 15 dollars.
I just called them, they dont have it today, but they will on tuesday.
How did you find that on the advance website? What query did you use?
Old Aug 31, 2012 | 09:51 PM
Creativeindy's Avatar
Arrrggggg
Originally Posted by Tony72Cutlass'S'
THATS AMAZING!
Probably same way I did when I bought mine a month ago from advance...type in "Detent Cable" and presto! LOL
Of course part of the issue is unless you know the cross reference or that 2 of the cables listed will in fact work on a TH350 it wont show when you click exact fit on your 72 Cutlass S.
What I did when I bought mine was search for Detent Cable, then I looked at both ends to make sure they matched mine since there are 2 styles(@ Trans end) of dentent's for the TH350 and I checked the lenght in the specs and sure enough it was the 04210 cable and I can verify it fits. It does however fit tight as it could stand to be about 2 more + inches for an easier fit. It's pretty right along the fire wall and by tight I mean tight.
Old Sep 2, 2012 | 11:05 AM
That's amazing, I already ordered the piece (15 dollars)
I should be there on Tuesday, this is great because my detent cable has never worked! I always have to downshift into 'S' on the highway if I want some power.
Any other tips for installation? Maybe on removal of the old cable??
Old Sep 8, 2012 | 12:05 PM
So after 3 hours of lying in a pool of blood and transmission fluid (wasnt sure which was which). Finally got the cable installed.
Why did it freeze in the first place? can any of you guess?
WELL, the cable was stuck in the sleeve, that was the first issue, but i'm guessing the previous owner slammed his foot on the gas so hard that it bent the tang that comes out of the transmission.
The tang was bent almost 30 degrees too far, which made it interfere with the casing and hence, not detent.
I spend 2 hours trying to re-bend that little tang, eventually, it was perfect, the new cable fit great. and with some minor adjustments, she downshifts when i slam the gas to the floor.
Interesting adventure, but at least the problem is solved.
Bitburger
Jul 14, 2015 02:28 PM
Bitburger
Jun 30, 2015 06:59 AM
malibu0578
Jun 12, 2015 01:48 PM
84oldsDelta88
Sep 30, 2011 09:20 PM
billykissell
Jun 7, 2011 05:17 AM
