WTB scattersheild olds/pontiac
Old Dec 11, 2011 | 07:58 AM
archeryshooter's Avatar
Tony
looking for used olds/ pontiac scattersheild
Old Dec 11, 2011 | 08:03 AM
Tony
scattersheild
im looking for a used olds/pontiac scattersheild thanks for any help
tony
Old Dec 11, 2011 | 11:31 AM
Lady72nRob71's Avatar
I moved this to the parts wanted section for best visibility.
Good luck in the search - bet someone has one...
Old Dec 11, 2011 | 11:39 AM
So, what is a scattershield? Got a description or pic?
Old Dec 11, 2011 | 12:21 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
It's a steel safety shroud that covers the clutch plates. They make big plates for auto trans cases too.
That way if the trans/clutch/flex plate blows up........ Stray parts don't saw your leg off on their way through the floor and out of the windshield.
Old Dec 11, 2011 | 01:04 PM
Rickman48's Avatar
Actually replaces the bellhousing - supposed to contain exploding flywheel and clutch parts, up to 10,000 psi.
There's also a motor plate, [optional] to protect the block.
Believe they're all drilled for all GM - Chevy could work!
Old Dec 11, 2011 | 01:05 PM
Tony
thanks
i thought it would help it out to be in more than one area
Old Dec 11, 2011 | 02:23 PM
Unhappy
Originally Posted by archeryshooter
thanks
Actually, each time someone posts to this thread it goes to the top of the 'New Posts' section of the site. Check there regularly. Also, if you have your email notification set to recieve new posts it will alert you through your email. Good luck finding your part.
Old Dec 11, 2011 | 04:16 PM
And if nothing shows up for like a week - feel free to 'bump' the thread to keep it on top.
Lots of people who have spare unwanted parts often go through the parts wanted section to see if they can sell something they no longer need.
Old Dec 16, 2011 | 12:10 PM
StickW31's Avatar
i have one with the block saver plate. $275 plus shipping from 06450
STeve
Old Dec 17, 2011 | 08:30 AM
Tony
STeve
Thanks if the deal goes through I got one a bit closer to home
Old Dec 17, 2011 | 09:33 AM
Funkwagon455's Avatar
Believe they're all drilled for all GM - Chevy could work![/QUOTE]
Negative, even if one were drilled for both bowties and Rockets, the starter clearance bump is located only on the driver's side. I'm sure you will find one for a reasonable cost pending that you don't need it by Christmas. Make sure to inquire about any modifications, you won't want to spend your money on one that has been a hot wrench victim. Good luck
Old Dec 25, 2011 | 05:51 PM
Tony
the guy is on vacation till after christmas i will know then
Thanks tony
Old Jan 11, 2012 | 07:08 PM
Tony
got one thanks guys
KQQLCAT
Sep 25, 2014 09:25 AM
rodknocker
Apr 17, 2006 11:02 AM
