Need 67 Toronado wheel beauty trim ring
Old May 30, 2011 | 11:12 PM
GM300hp's Avatar
I have a 1967 Toronado. Last fall while on a Sunday drive the right front tire exploded. Lost the wheel's factory beauty trim ring. The tire tread also damaged the panel that runs between the wheels at the bottom of the body below the passenger door. Looking to find replacement parts if anyone out there can help. Thank you for your time.
Old May 31, 2011 | 06:19 AM
rocketraider's Avatar
Oldsdruid
Disc brake or drum brake car? Trim rings are different between them.
Old Jun 2, 2011 | 10:52 AM
GM300hp's Avatar
Trim ring follow up
My 67 Toronado has drum brakes at all four corners.
Old Jun 2, 2011 | 06:06 PM
Oldsdruid
All 66 Toronados and 67 drum brake cars use the same trim ring, so that may make finding one easier. I have a couple of driver quality disc brake rings, but they are different enough from yours to be noticeable. A lot narrower.
Old Jun 21, 2011 | 10:07 PM
GM300hp's Avatar
67 drum brake beauty trim ring or deluxe wheel cover
OK, so I have posted that I am looking for a 66 or 67 drum brake beauty trim ring for my 67 Toronado. While checking craigslist in Minneapolis, MN, I came across three 67 Toronado deluxe full wheel covers in pretty good condition. I picked them up. So I am looking to find a trim ring as well as a deluxe full wheel cover. Thanks for your help.
dz442
Apr 13, 2015 06:14 PM
oldspackrat
Aug 10, 2014 10:03 PM
HolidayCoupe
Dec 17, 2009 09:58 AM
1973olds98
Ninety-Eight
Oct 21, 2009 07:30 PM
