Rubber seal on heater core
Does anyone know where I can buy a rubber seal (not sure what its proper name is?) for the heater core? It goes over both of the heater core tubes and, I believe, anchors them against the fire wall. The car is a 72 Cutlass 442.
Thanks.
Steve
Thanks.
Steve
I think he's talking about the fairly thick foam rubber piece that slips over the heater core outlets. It keeps them isolated from rubbing against the interior side of the firewall.
If you can find some dense closed cell foam in that's about 2" or so thick you should be able to make one. Again...the foam is fairly dense...nothing like seat foam density.
Here's a couple pics of what I think he is looking for....this is a real "rubbery" type foam this one is from a non-AC car...don't know if AC cars have a different piece or not):
Yup, that's it. I've checked with Fusick, YearOne, The Part's Place, BAP, USAParts, AND ebay. Nada! The guy at Fusick's was the only one who admitted to even knowing what I'm talking about.
I guess making one is the only option left, though I'd guess its important to find the right material that will stand up to the heat.
Thanks everyone. I'll keep looking around. I've yet to check a radiator place but will put that on my list of stops to make.
Dan...I've been thinking the same thing. I replaced this heater core a number of years ago and I'm wonderin if the gasket (if that's what's called) came with the core. This heater core appears to be in good shape so I'd hate to buy a new one just to get the gasket but that may be what I have to do.
Thanks.
Thanks.
Ok...NEVER MIND!!!...I gave up the search for this and instead spent some time cleaning up the old one. Washed it real well and then brushed it lightly with a fine wire brush. It took all the dirt and caked on rust off and it actually looks pretty good. I'll re-use it and just apply some silcone around the tubes and on the side that is up against the firewall when I re-install it.
Thanks.
Thanks.
