WANTED 1972 W30 water pump short shaft
Old Yesterday | 03:08 PM
1977442's Avatar
I'm looking for a 5.072" short shaft water pump for my 1972 W30, casting 408328.
Old Yesterday | 07:32 PM
2blu442's Avatar
Are you sure about that part number? The reference I'm looking at says that's correct for 71-72 non-W30. But for the W30 or 3.73 rear end, non-AC would be 408329. For heavy duty cooling or AC application including W30 would be 407536. I'm looking at the Supercars unlimited "by the numbers" book. John
Old Yesterday | 07:39 PM
Texas442's Avatar
1971 442 conv
Your car is non-AC, correct? If so, then you need the 5.6” shaft water pump not 5.072"
Old Yesterday | 08:03 PM
Run to Rund's Avatar
I have several new/remfg. Carquest 5.1" water pumps that I bought 30+ years ago and never used. Cast and stamped impellers, not that casting number, however.
Old Today | 07:29 AM
As I noted in your other thread, every single 1972 W30 without A/C (which is all of them) came with a 5.6" pump. Once again, do NOT rely on third party information like that from the web. I get my info from factory literature.
Old Today | 01:23 PM
v8al's Avatar
Registered Olds Owner
ALL 1972 W30's came without AC! Any 1972 W30 with AC was added after the car was built at the factory. (This does not apply to Hurst/Olds)
Specs book specifically calls it out on the W30 option.
Old Today | 01:24 PM
And STILL a 5.6" water pump, which is the pertinent part of this.
Old Today | 01:29 PM
v8al's Avatar
As I noted in your other thread, every single 1971 W30 without A/C came with a 5.6" pump. Once again, do NOT rely on third party information like that from the web. I get my info from factory literature.
I question if quoting a 1971 reference is pertinent when the OP is asking about a 1972.
Old Today | 01:50 PM
That was a typo on my part. Should have said 1972. In any case, 71 and 72 are the same. 5.6" on all 1972 and all 1971 w/o A/C. Same P/N, same casting number.
Old Today | 01:51 PM
I edited the post. Thanks for catching that typo.
Old Today | 02:02 PM
v8al's Avatar
Sure, sorry I was blunt about it. It's a pet peeve of mine when people talk about 72 W30's and AC.
dsa2207
Apr 19, 2024 03:20 AM
johnaph68
Jan 8, 2020 04:14 PM
MY71W30
Oct 13, 2015 03:48 AM
cdoering
Aug 9, 2015 10:11 AM
jensenracing77
Jul 15, 2014 02:27 PM
