1966 delta 88 frame
Old May 24, 2026 | 04:21 PM
DailyOlds's Avatar
1966 delta 88 frame
Hello I will be taking a trip in June from Wisconsin to Kentucky and id like to pick up a frame for a 66 delta 88 on the way. It can be a parts car as long as the frame is solid and id like to keep it under 1000 bucks. Let me know what you have for sale and let's make a deal.
Old May 25, 2026 | 05:31 AM
Minibike Mark's Avatar
Does it have to be a 1966? I have a 1968 and I am in Wisconsin:
https://classicoldsmobile.com/forums...-frame-182839/
Old May 25, 2026 | 09:01 AM
66_Jetstar's Avatar
I'm no expert in the big car stuff, but over in A-body land four door frames are different than two doors.. you might put a study out on it and specify what you need.
Old May 25, 2026 | 09:33 AM
455Dave's Avatar
I may have what you need. PM me if you’re interested in discussing -I’m in the St. Louis MO area. 88 frames are different than 98 frames (different wheel bases) and convertibles got special HD frames…but 2 dr and 4drs got the same frames. The part numbers vary by year/engine and transmission…likely due to predrilled hole locations.
Dave.
Old May 25, 2026 | 01:50 PM
DailyOlds's Avatar
cutlass did have 3 frame lengths, 2 door, sedan/flatop wagon and vista cruiser from 68 to 72
All 65-66 88 oldsmobiles are the same wheelbase. I have swapped 2 door and 4 door frames around. Only difference is the 98s being longer.
Old May 25, 2026 | 02:00 PM
66_Jetstar's Avatar
Thanks for the info fellas.
Littleoldme1
Oct 5, 2021 01:00 PM
HarOlds
Mar 6, 2016 10:28 PM
hurst68olds
Nov 23, 2015 12:16 PM
Rodr
Oct 8, 2006 08:54 AM
JoshF85
Aug 3, 2005 01:29 PM
