1966 delta 88 frame
1966 delta 88 frame
Hello I will be taking a trip in June from Wisconsin to Kentucky and id like to pick up a frame for a 66 delta 88 on the way. It can be a parts car as long as the frame is solid and id like to keep it under 1000 bucks. Let me know what you have for sale and let's make a deal.
Does it have to be a 1966? I have a 1968 and I am in Wisconsin:
https://classicoldsmobile.com/forums...-frame-182839/
I may have what you need. PM me if you’re interested in discussing -I’m in the St. Louis MO area. 88 frames are different than 98 frames (different wheel bases) and convertibles got special HD frames…but 2 dr and 4drs got the same frames. The part numbers vary by year/engine and transmission…likely due to predrilled hole locations.
Dave.
Dave.
All 65-66 88 oldsmobiles are the same wheelbase. I have swapped 2 door and 4 door frames around. Only difference is the 98s being longer.
