70 vista parts needed
Old Oct 21, 2009 | 03:49 AM
70vista's Avatar
Hi, I am doing a 70 vista cruiser and need the following pieces. Need the r/r wheel opening moulding,r/r lower moulding behind wheel that seperates the woodgrain and paint,rear gate handle,lowermoulding on the gate that seperates the wodgrain from paint, rear gate opening trim,front grilles that are in one piece,door window trim around glass on outside and interior trim panels the cover the "C" pillar on the inside. I also would be interested in a 70-72 vista cruiser bigblock car for parts if it had a lot of the thing I need. I also need the roof mouldings needed to two tone the roof.
Sorry for posting in two spots but relized I may have put this in the wrong section. Thanks
__________________
Old Oct 31, 2009 | 06:31 PM
70vista's Avatar
Still looking for all these parts plus I need a long tail 400 transmission. I think that is what is used in the 70 vista cruiser.
Old Oct 31, 2009 | 06:47 PM
ent72olds's Avatar
Registered Luser
I just need to get to the shop to get you a pic of the wheel opening molding...it is in vg condition. But I still want you to see a pic first. I will get one this week...I promise!
Old Oct 31, 2009 | 07:22 PM
70vista's Avatar
Thanks I appreciate it. I would like to take all the stainless to the polisher at the same time so finding the wheel opening and the small piece on the lower rear quater is most important right now,
Old Nov 2, 2009 | 10:19 AM
rocwal's Avatar
70 vista parts
Hi I was to a yard in central Maine this past weekend and they had a complet Vista sitting the sheet metal was bad , all the glass was good , i think the stainless was all there , if your are intrested let me know and I'll get their phone number so you can contac them direct . Mail me at d.rocwal@roadrunner.com
rocwal
Dan B
Old Nov 2, 2009 | 06:44 PM
70vista's Avatar
Thanks Dan, Did you know what year it was? I would be interested in the number for the yard.
Old Nov 5, 2009 | 03:33 AM
Cassie09's Avatar
Parts 4 U
Hi Steve,
If your still in need of '70 Vista Parts- I have just about everything.
I live in the SFV Area of Los Angeles County and can ship to you.
Basically I have the whole Car, Interior, Exterior, Motor, Trans etc..
Except for the passenger side front fender and Windshield- which was damaged. Everything is in Very Good To excellent Shape.
My Email is Cassieraef2009@aim.com
Old Dec 14, 2009 | 03:34 AM
70vista's Avatar
Hi,
Just a update on my parts wanted. I still need the following parts in Very Good Condition. Thanks
1. Right and Left "C" pillar lower mldgs.
2. R/R lower trim behind wheel well (seperates woodgrain and paint).
3. R/R wheel opening Mldg. (no longer needed)
4. Rear Gate Lock and wire harness for it.
5. Complete roof rack assembly.
6. Rear Gate opening rubber step plate pieces.
7. Left A/C vent
8. L/F outer door window frame trim.
9. Outside tailgate handle.
10. Tailgate lower outside mldg (seperates woodgrain)
11. Turbo 400 Transmission (This should be a longtail trans). I also need the kickdown switch bracket and wireing to it.
12. The Drive shaft for a wgaon 455/400 car
13. The Motor Mount pads that bolt to the frame.
14. #671 anti-spin diff. carrier 12 bolt/10 bolt ring "O" type for 3.08 gears.
15. Dash plastic (the part that holds the wiper,rear window switch) if it is in good shape.
16. Right and Left rear door lower hinges if the rollers and springs are in tact.
17. Rear Gate hinge if tight.
18. Front and rear door glass run channels if they are not all torn.
19. Rear gate glass run channel (where the rear gate glass runs into the body).
20. Rear liecence plate light assembly.
Old Jan 4, 2011 | 06:21 AM
MHENDERSON's Avatar
Ayottes auto parts
Vince 539-4888 Poland maine He has 3-4 of them
Old Jan 4, 2011 | 12:29 PM
MHENDERSON's Avatar
Area code 207 for Me.
Old Jan 4, 2011 | 12:43 PM
I was able to find a complete set of 69 chrome and extra set of glassfor my Vista from one of those Arizona yards always listed in Hemmings. Sorry, I forget which one.
Old Jan 4, 2011 | 05:14 PM
1001coins's Avatar
i have the tailgate hinge and a 400 long shaft trans from a 75 delta. im in chicago. chris 773 418 0330
Old Jan 17, 2011 | 06:07 PM
oldspackrat's Avatar
Vista parts here.
Hi,
I'm in Indianapolis & have some of the parts you need. Give me a call if you want with what you still need & I'll track down what I have & get some pix to you. I have a luggage rack & most of the trim & a trans or two & the vent & dash parts. I bought new glass run channel for my doors & tail gate. I can get that info. for you also. Might also have the lic plate stuff.
Scott
C. 317-727-7041
Old Jan 17, 2011 | 06:32 PM
70vista's Avatar
Thanks for the leads guys. I have found most of the parts but still looking for upper "C" pillar mldgs and plate lite.
Old Jan 18, 2011 | 05:42 PM
442Harv's Avatar
The C piller is the back piller back of rear seat,correct? I think I have a set. Sold my VC, so may be interested in selling.
Old Jan 18, 2011 | 05:50 PM
70vista's Avatar
Thanks, Yes they are behind the rear seat from the rear of the rear door opening to the front of the rear side glass. I am interested if you have them. Thanks again
Old Jan 20, 2011 | 06:23 PM
70vista's Avatar
I was wrong on location. These are the lower "C" pillar mldgs (Dog leg area). Need right and left.
Old Jan 20, 2011 | 06:57 PM
jensenracing77's Avatar
i should have a set of these. would you have a picture of the area you are talking about and how long the ones you need are? i took some trim off before i cut the dog legs out of one and don't know what one goes where.
Old Jan 21, 2011 | 03:53 AM
70vista's Avatar
I will get a picture posted this weekend of the part I need. Thanks
Old Jan 21, 2011 | 06:34 AM
Bluevista's Avatar
Registered
I have a license plate lite, front or rear?
It's a little bent and rust encrusted but the bulb housing, contact and wire look okay.
The lens is broken on one end and cracked but I thinks you you can get those from Fusick.
If you want it PM me your address and I'll send it out. If you like it send me whatever it cost for shipping , if you don't like it pitch it in the trash and send me whatever it cost for shipping.
Old Jan 22, 2011 | 11:05 AM
70vista's Avatar
Hi, Here are a couple of shots of the piece I need. I need right and left. Thanks
Old Jan 22, 2011 | 12:26 PM
Bluevista's Avatar
Registered
Those are almost always messed up on the top from being exposed to the sun. That plastic can't take UV exposure, they should of never used it there but they did.
Mine were bad so I rebuilt the tops with flexible bumper repair putty and then I skimmed over the top surface with some 2K glazing putty and textured it with a sponge until it looked just like the rest of it, sort of.
The top interior C pillar covers get brittle as glass and you have to be really careful removing and installing them too.
Old Jan 22, 2011 | 03:31 PM
70vista's Avatar
I know these get brittle from the way the sit in the car but I was hoping someone with a car from the northeast would have them with less sun exposure.
Old Jan 22, 2011 | 04:31 PM
1001coins's Avatar
there is a guy parting out a 70 vista on ebay under salvage vehicles. he is in south dakota same color interior as yours. looks like he has everything you need
Old Jan 22, 2011 | 06:01 PM
70vista's Avatar
Thanks for the lead. I did see that car on ebay but thought he was selling the car as a whole. I will check again.
Old Jan 22, 2011 | 06:26 PM
i feel bad now. i was thinking something much differant. for some reason i was thinking trim on the outside of the car. i must not have looked hard enough at your post. i can look but most likely the ones on this car will be bad. it is from AZ and most of the interior is shot. sorry.
Old Jan 29, 2011 | 05:45 PM
70vista's Avatar
Was able to get the parts from the e-bay car 1001coins mentioned. Hope the pieces are as good as the guy says.
Old Jan 29, 2011 | 06:32 PM
2blu442's Avatar
Sorry, I hadn't read your post for a while. If the lower C pillar covers aren't good enough when they show up let me know. I believe I have an extra set.
John
Old Feb 1, 2011 | 05:05 PM
70vista's Avatar
Will let you know if these aren't decent when I get them. Thanks
John
Old Feb 6, 2011 | 09:44 AM
70vista's Avatar
Received the lamp assembly and it looks in very restorable condition. Thank You
Old Jul 19, 2011 | 06:50 PM
  #31
70vista's Avatar
Well the guy who had all the parts stiffed me and got nothing from him.
I still need a lot of the parts I had listed minus the mldgs and plate lite. If anyone has any leads on thes eparts I would appreciate it. Thanks Steve
Old Jul 19, 2011 | 08:22 PM
  #32
Steve,
I've got some of the parts on your list, can you give me a call for more info & prices? I've got all the stuff at my house & can look at it on the phone with you & get you pix as well.
Thanks.
Scott
c. 317-727-7041
Old Jul 19, 2011 | 09:56 PM
  #33
2blu442's Avatar
Steve, after you get the items Scott has let me know what you still need.
John
Old Jul 20, 2011 | 04:56 PM
  #34
70vista's Avatar
Thanks guys, I got to remake the list again and will call. Thanks Steve
Old Aug 4, 2011 | 09:14 AM
  #35
70vista's Avatar
This is the updated parts list I still need.
2. Rear Gate Lock and wire harness for it.
5. Complete roof rack assembly (just need the stainless upper bars undented).
7. kickdown switch bracket and wiring to it (converting from turbo 350 to 400).
8. The Drive shaft for a wgaon 455/400 car
9. Rear Gate hinge if tight.
Old Dec 16, 2011 | 03:38 AM
  #36
70vista's Avatar
Just bringing to the top. Still need everthing in the previous post except for the roof rack and gate hinge. Scott if you read this do you still have some of this stuff?? Thanks
Old Dec 16, 2011 | 07:50 PM
  #37
Steve,
I've got those two ugly c pillar moldings. They are better than nothing, that's about all I can say about them.
I do have an extra key cylinder for a vista tail gate, but no wiring.
Give me a call if you want.
Thanks.
Scott
c. 317-727-7041
Old Dec 29, 2011 | 03:35 AM
  #38
70vista's Avatar
Thanks Scott, If the "C" pillars are all crumblely would not be able to use them. I don't mind painting them put have to be solid. I also need a dash ash tray door and hardware. Does the rear cylinder have a key and bezel? Thanks
Originally Posted by oldspackrat
Steve,
Thanks.
Scott
c. 317-727-7041
Old Dec 29, 2011 | 05:08 AM
  #39
Giftman23's Avatar
If 70Vista passes on the c pillar moldings, please PM me with a few pics - I need a passenger side as mine has disentigrated - something is better than nothing. Thanks!
Old Dec 30, 2011 | 11:08 AM
  #40
70vista, I have just the cylinder. I thought I had another bezel, but it's hiding from me apparently.
I believe one of the chevelle wagon guys is reproducing those. You might check with Pete Lohrman? or do a search for chevelle wagon parts? I've got one nice ashtray door, you'll have to paint/dye to match, & I might have two of the shims for it also, but not sure. How about $20.00 for it & if I have the shims, I'll include them also.
giftman23,
Here is a link to a picture of the drivers side, pass side is similiar to this one. These have been painted at one time. With some work & more paint, they would look ok, but not great. Give me a call if you want.
Thanks.
Scott
c. 317-727-7041
http://i856.photobucket.com/albums/a...nknown-117.jpg
http://i856.photobucket.com/albums/a...nknown-116.jpg
