68 442 upper control arms shims
Old Apr 6, 2022 | 04:17 PM
W-27's Avatar
Looking for a complete set of upper control arm shims. I beleive that they came in a set of 12 and (3) different sizes 0.030", 0.060" & 0.120". New or in great shape.
Old Apr 6, 2022 | 09:07 PM
If you're not a 100% purist:
Amazon.com: 144 Pieces Auto Alignment Body Shim 1/16" 1/64" 1/32" 1/8" Alignment Shims Assortment Set : Automotive Amazon.com: 144 Pieces Auto Alignment Body Shim 1/16" 1/64" 1/32" 1/8" Alignment Shims Assortment Set : Automotive
Old Apr 7, 2022 | 06:00 AM
I think the whole point is that he IS.
Old Apr 7, 2022 | 07:07 AM
Not with that fake w27 diff cover... How many cars were re-aligned at the dealer with factory shims under warranty?
Old Apr 7, 2022 | 09:10 AM
W-27's Avatar
It is original!
I beg your pardon the W-27 cover is an original (not a fake) bought from another Oldsmobile collector in Burke VA many years ago and it wasnt cheap. In the case of the console latch which no one reproduces i made one by hand (made in the USA) I have managed so far not to put any parts made in China on my automobile and would like to continue. Even my "Force Air Induction" is original and made in the USA. I have never bought ANYTHING that was made in China that was of good quality so why should i start now. I will make some by hand before i buy chinese. Their standards are not the same.
Old Apr 7, 2022 | 09:57 AM
ROCKETMAN269V's Avatar
........ How many cars were re-aligned at the dealer with factory shims under warranty?
When I worked at the Olds dealership, we re-used factory shims, that were removed from cars, to correct the alignment; had piles of them in the alignment pit.
Old Apr 7, 2022 | 09:59 AM
If you're not in a hurry, and can let me know which ones you need, I should be able to get you oem used shims.
Old Apr 7, 2022 | 11:28 AM
W-27's Avatar
Shims
Not in a hurry but would love to find some soon. I dont have part numbers but i know they were about (12) total 0.030", 0.060" & 0.120" plkease let me know if you find some.
Old Apr 7, 2022 | 11:43 AM
Well this is interesting. Apparently A-body shims are different from those used on full size cars. Who knew?
Old Apr 7, 2022 | 12:29 PM
jensenracing77's Avatar
I truly don't mean anything other than to inform you. Please don't be upset with me but sadly, you got took. This is a repop cover.
Old Apr 7, 2022 | 12:44 PM
W-27's Avatar
We had a repop and the original side-by-side and there is a difference in the thickness of the aluminum and in the casting used originally and it was obvious but think what you want. I am the only one that as to know the truth.
Old Apr 7, 2022 | 12:45 PM
alain's Avatar
ouch
Alain red W-31
P/S just do your best
Old Apr 7, 2022 | 12:47 PM
........i know they were about (12) total 0.030", 0.060" & 0.120" .........
As I explained in your PM, each vehicle is unique as to where and how many shims are placed. By adding or subtracting equal amounts, you can change the Camber; by adding or subtracting from either the front or rear position, you alter the Caster. This is an over simplification, but you get the idea. The vehicle would have to be checked on alignment equipment to determine if, where and how many shims would need to be added/subtracted. If you were closer to me I would have you bring me the car. I have a Hunter alignment set-up and have been doing alignments for ......a long time.
Old Apr 7, 2022 | 12:57 PM
W-27's Avatar
Of course, i totally understand but my shims are a real mess and none are originals so i could measure each one and tell you the total thickness that i would need. I wish you were closer i would bring the automobile to you.
Old Apr 7, 2022 | 01:43 PM
There are more than one repop out there and this one is the better of the two that I have seen but this is a repop. If you have had a real one you can spot a repop from a mile away weather it is the better repop or the bad repops. Again, I am only trying to inform, not trying to nitpick your stuff.
Old Apr 7, 2022 | 02:15 PM
It doesn't matter what the thicknesses were before, other than to get you close. The fact that the suspension has been apart says that the only way to get the correct shim pack thickness is to perform a proper alignment. That's why the parts book says "AR" - as required. Just loosening and tightening suspension bolts will change things. Unless you only plan to push the car off and on the trailer at shows, do it right.
Old Apr 7, 2022 | 02:36 PM
W-27's Avatar
Joe, i plan on it. I keeped each set of shims (4) labeled and bagged so that i can install the same thickness prior to a front end alignment (it wont be perfect but close to what i had).
Old Apr 7, 2022 | 02:38 PM
Boiler_81's Avatar
I did a search on past threads concerning original vs reproduction. I couldn't find one with good clear photos of the various reproductions vs an original. I would be interested in seeing such a comparison.
Old Apr 7, 2022 | 03:00 PM
I would not worry about the shims:
Old Apr 7, 2022 | 04:12 PM
The imperfection I circled in this picture is the simplest way to tell. There are others as well
Old Apr 7, 2022 | 04:29 PM
W-27's Avatar
This may clear my situation on the shims. They are all different sizes but i strongly suspect that the ones in the middle of the first picture is original in size. I also found a set for Corvette's in which size, thickness and original part number match. Here is the link in case anyone else may be interested in them (USA made): https://www.ebay.com/itm/153960594674
Old Apr 8, 2022 | 04:57 PM
joesw31's Avatar
I bought those shims a while back as I do my own alignments and I was pleased with them.
Old Apr 8, 2022 | 08:42 PM
W-27's Avatar
That is good to know but just curious on how you do your own alignments without a big Hunter? Is it something that anyone can do with the correct tools? I would love to do my own if i could.
Old Apr 9, 2022 | 01:50 AM
joesw31's Avatar
You don’t need a large alignment machine to do an alignment. I use a camber/ caster gauge, toe plates, and you may have to use the string method to make sure your front wheels are aligned with the rear wheels.
Old Apr 9, 2022 | 06:24 AM
RetroRanger's Avatar
72 Olds CS
https://www.summitracing.com/search/...lignment-tools
theres lots of home alignmrent options
Old Apr 9, 2022 | 06:55 AM
The basic problem with a DIY alignment set-up is you can't take the "runout" of your wheels. In other words, if one/both of your front wheel outer lips are slightly out of true with the center, where it attaches to the hub or the drum/rotor surface isn't true or has dirt between the wheel and mounting surface, you can't get an accurate reading. The set-up that I have, while being portable, also allows me to compensate for an out of true situation. When doing an alignment, you're actually aligning the spindles, not the wheels. The first thing that I do when checking alignment, after checking for worn ball joints and loose wheel bearings, is to attach my alignment heads and slowly rotate the wheel, while watching a bubble level. By adjusting three thumb screws that hold the head to the mounting fixture, I get the alignment head in a true vertical plane. Then any readings that I get are true to the spindle.
Old Apr 9, 2022 | 06:57 AM
I also do my own alignments. The biggest investment is a set of turn plates so you can turn the wheels to set camber. I was fortunate to find a used set relatively inexpensively at Carlisle. I know some people use layers of wax paper or greased masonite to facilitate turning the wheels, but that seems squirrrelly to me. I've tried several different types of toe gauges. These two aluminum plates with tape measures have been the easiest to use and most accurate. There are a variety of magnetic bubble gauges for caster and camber.
Old Apr 9, 2022 | 07:04 AM
The magnetic gauge I posted above mounts to the hub, not the wheel, but that requires you to remove the center cap which can be a PITA. Frankly, if your wheels are that far off, you'll probably feel it as vibration at speed. And if you really care, just check alignment with the wheels clocked a couple of different ways to check.
Old Apr 9, 2022 | 04:54 PM
W-27's Avatar
With very few shops willing to align older automobiles like ours this is great information. You can probably buy all the tools for about the same price as an alignment job.
Old Apr 9, 2022 | 05:03 PM
W-27's Avatar
What specific tool do you guys use to tighten the (2) cam 11/16" bolts on the drive side? They are hard to get to.
Old Apr 10, 2022 | 09:30 AM
  #31
W-27's Avatar
Truth be told the turn plates are not cheap but worth searching for. It is refreshing to know that one can actually do their own front end alignment providing they have all the necessery tools and knowledge on how to go about it. I have seen Snap On, Hunter and Weaver turn plates average used price of $500.00 and not sure which brand as more longevity and accuracy than the others. The search for knowledge and tools will go on.
Old Apr 10, 2022 | 09:35 AM
  #32
There's nothing magic about the turn plates - just bearings and sliders that avoid preloading the suspension when you turn. Frankly the Chinesium ones are fine when you do one alignment a year or less. Also, mine are ancient and I got them at Carlisle for like $50. Keep your eyes peeled.
Old Apr 10, 2022 | 10:36 AM
  #33
W-27's Avatar
Thanks Joe.
Old Apr 10, 2022 | 10:47 AM
  #34
Thanks Joe.
I should probably point out that my turn plates live in Loudoun County. Just sayin'
Old Apr 10, 2022 | 03:20 PM
  #35
W-27's Avatar
Joe, i truly appreciate the offer and i may take you up on it but i have a mobile welder coming to weld the washers in the pictures, than i go to shimming and in the end i will need to align the front end. I will keep you posted as i still want to get original ignition, glove box key's made. Louis.
matt506
May 30, 2020 11:15 AM
cbartonbrown
Oct 7, 2019 08:26 AM
hotwheels69
Apr 3, 2013 07:48 AM
hvysupreme
Apr 12, 2012 07:13 PM
nohn
Sep 22, 2007 11:26 AM
