66-67 Manual trans. throttle bell crank
Old Jan 7, 2022 | 01:30 AM
66Rocket425's Avatar
First ad on this site, so bear with me. Thanks Looking for bell crank for a conversion from auto to manual 66 cutlass. I have all the auto components so not sure if I need underhood parts or the whole assembly.
Old Jan 7, 2022 | 04:32 AM
Oldsmaniac's Avatar
You only need the parts if you want to make it factory looking...as in no kick down switch otherwise its not needed and the auto style throttle mech. will work fine.
Old Jan 7, 2022 | 12:17 PM
You only need the parts if you want o make it factory looking...as in no kick down switch otherwise its not needed and the auto style throttle mech. will work fine.
Old Jan 7, 2022 | 01:25 PM
Tri-Carb's Avatar
As I recall a Tri Carb bell crank is unique.
Old Jan 7, 2022 | 09:42 PM
Old Jan 7, 2022 | 09:43 PM
Thanks Much, Oldsmaniac, good to know.
Old Jan 8, 2022 | 08:40 AM
66-3X2 442's Avatar
I might can help you. Contact me @ pchopesq@aol.com
Mike
Doug Carner
Tech Editor's Desk
Jan 17, 2020 03:09 AM
Delasangre4231
Aug 7, 2018 11:59 AM
Delmont 88 PA
Sep 9, 2014 08:07 PM
oldsmosteel
Apr 28, 2013 12:39 PM
dmcianfa
Oct 29, 2010 10:59 AM
