1973 Delta 88 Royale parts needed
Old Aug 14, 2021 | 04:06 PM
Pookie357's Avatar
I am looking for the following parts for my 1073 Oldsmobile Delta 88 Royale
1. rear panel emblems
2. glove compartment lock switch , will not stay latched and constantly falls open whenever I hit a bump
3. Driver side sun visor will not stay up, do not know if I need to replace the arm.
Any help/suggestions is greatly appreciated. Thanks
Old Aug 14, 2021 | 07:49 PM
rocketraider's Avatar
Oldsdruid
If you're talking about the trunk lock cover it's gonna be hard to find. The lurex plastic insert just does not hold up. When I had my 73 Royale I got one for a 77-85 Royale which fit right and the red insert looked great against the Cranberry paint.
The glovebox lock can be adjusted. If you have the 1973 factory Chassis Service Manual (if not, you should get a copy) the striker adjustment procedure is in it along with procedure for removal and replacement of the lock cylinder.
You should be able to find a replacement nylon bushing for your visor. It will restore tension on the visor shaft and keep it up.
At least all yours does is drop down. The one on mine would regularly fall completely out of the windshield header. Too involved for me to fix it- the entire windshield frame had to be disassembled.
Your car is a convertible, right?
Old Aug 15, 2021 | 05:41 PM
bigdooly's Avatar
If you need the glovebox latch I have it.
if your car is NOT a convertible i have visors and brackets.
I sold the convertible visors & brackets I had.
Jim
Old Aug 18, 2021 | 09:14 AM
Pookie357's Avatar
yes it is a convertible. I will order the manual you suggested. Will the manual also show me how to replace the nylon bushing for my visor? Do you know if I can use another year lock cylinder or do I need to stick with 1973?, should I check ebay for the parts?
Old Aug 18, 2021 | 09:16 AM
Pookie357's Avatar
i believe I need the lock, the latch is in place, the lock just wont latch completely so drops down when I hit a bump. Can you send me a pic of the latch and the price incase I do need it?
Old Aug 18, 2021 | 10:54 AM
bigdooly's Avatar
Latch.
As far as Latch I was at work already when I saw your message I have 3 das sections to remove them from I'll send pictures tomorrow if I have time.
Jjmack74
Jan 29, 2021 01:22 AM
gunmetal71
Oct 28, 2016 01:33 PM
delta88nj
Aug 13, 2014 11:01 PM
cus
Apr 9, 2014 03:44 PM
<Dennis Oliver>
Mar 14, 2004 08:58 AM
