1967 kickdown switch wanted
Old Sep 30, 2020 | 06:30 AM
My Grandma's 67 Cutlass's Avatar
Al
I need this kickdown switch for my 67 Cutlass 330 . It gets mounted to the intake manifold. Tranny is a Super Turbine 300 AKA Jetaway, the Kickdown Part # is OE group 4.057, p/n 1993355. Does anyone know where I can find one? It's a three prong.
Thanks. email me at
gambyal@optonline.net
Last edited by My Grandma's 67 Cutlass; Oct 1, 2020 at 07:25 AM. Reason: added part number
Old Sep 30, 2020 | 06:56 AM
rocketraider's Avatar
Oldsdruid
It's not a Powerglide. It's a SuperTurbine 300 AKA Jetaway (don't confuse it with 56-60 Jetaway HydraMatic). All a PG and Jetaway have in common is they're 2 speed transmissions.
OE part number is Group 4.057, p/n 1993355, transmission throttle control switch 1965-67 V8 AT except Toronado or trailer towing package. Works on Cutlass, 88 and Ninety Eight.
If the car is six cylinder p/n is 1993327.
What's wrong with the one you have? It controls two things, downshift and torque converter stator angle. If it checks good electrically your issue is at the transmission itself, either the downshift or stator solenoid.
If you have a 67 Olds factory service manual it outlines troubleshooting steps and switch adjustment.
Old Sep 30, 2020 | 07:52 AM
Al
thanks so much for the info. Been calling everywhere and checking the web for that part number but getting nowhere. Any further advise>
Old Sep 30, 2020 | 09:50 AM
Oldsdruid
Post in parts wanted and see if someone has a good one they'll part with. Keep in mind what you need can come from any 65-67 Olds except a Toronado. Good luck.
Old Sep 30, 2020 | 03:03 PM
Al
Thanks for the info. I have so much trouble navigating on this site, How do I post to parts wanted?
Old Nov 4, 2020 | 07:52 AM
65B01Delta's Avatar
PM Sent
Old Nov 4, 2020 | 08:05 AM
ROCKETMAN269V's Avatar
[QUOTE=My Grandma's 67 Cutlass;1282850]
.............. It gets mounted to the intake manifold.......... /QUOTE]
It actually attaches to the firewall, with the throttle pedal arm passing through to the inside.
Old Nov 5, 2020 | 04:44 AM
lemoldsnut's Avatar
I have it if you are still looking.
Larry
lemoldsnut@aol.com
Old Nov 5, 2020 | 10:14 PM
cfair's Avatar
You can also rebuild/recondition it.
To do so gently bend the tabs on the outer ring that hold the Bakelite (plastic) against the metal housing. Inside you’ll find some brass contacts mounted on springs. If you solder a drop of molten solder onto the worn flat contacts, you’ll be able to restore the electrical function. But to get it to operate without hanging up the throttle, you’ll need to grind the contact heights back to factory height.
To figure out the factory height, take the best of your contacts and measure it with a vernier caliper. Then match the others to that best-guess height. In my switch, if my memory serves, the height was .060. I could be wrong, so, please measure yours before accepting my measurement.
Hope that helps. These switches are rare now. If you dig around this site, you might find my reconditioning advice with pictures.
Cheers
Chris
cfair
Jan 31, 2024 11:27 PM
Big Dawg
Sep 26, 2018 06:24 PM
jstrits
Jan 4, 2014 04:05 PM
Flye
Jul 15, 2009 09:25 PM
nevadacutlass
Oct 8, 2007 07:28 PM
