70-71-72 Tire Tool Trunk Mounting Clips
Old May 23, 2020 | 03:50 PM
kencpless@gmail.com's Avatar
I need a pair of the clips that hold the tire tool to the trunk floor. These clips were used for cars with a "specialty wheel", SSI / SSII / SSIII. Thanks!
Old May 23, 2020 | 04:59 PM
jharsh's Avatar
Try Fusick: http://www.fusickautomotiveproducts....p?number=LWC66
Old May 23, 2020 | 05:59 PM
Thanks jharsh! I don’t know why I didn’t check Fusick. I guess I was surprised that Inline Tube didn’t have them and didn’t go further.
Old May 23, 2020 | 06:24 PM
scrappie's Avatar
Inline has them part #11122, $18.50 set
Old May 23, 2020 | 07:10 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
There are a few right ways to mount these and a few wrong ways depending on year and plant of manufacture.
Which specific year are you looking for and which plant did it come from?
Someone will need to post a good pic with measurements for the year of your car.
Old May 23, 2020 | 07:24 PM
My car is a ‘71 Convertible, built at Lansing. The assembly manual gives location specs, but I’ve heard that they’re somewhat random in exact spacing. I do have a question about the small tab on the end of the clip ... does it require an additional hole to be drilled? I assume it’s there to help keep the clip straight.
Old May 28, 2020 | 01:13 PM
Good question.
In my 68 I drilled one pilot hole for each sheet metal screw. Applied some grease to prevent rust and tightened them down with light torque. I don't remember the locating tabs being present on these clips.
I think/thought there were subtle indents in the trunk pan to act as drill locators just for the screws. I doubt the factory would have spec'ed open holes in the pan, at least I don't see it on 68s.
Old May 28, 2020 | 02:59 PM
Thanks for the advice!
Old May 28, 2020 | 03:48 PM
Gerald Nickels's Avatar
I have two if needed. Make offer and yes not repo.
Old May 28, 2020 | 06:39 PM
scrappie's Avatar
I have the original clips and trunk floor from Lansing built car that I can verify type and location for you if needed?
Old May 28, 2020 | 06:45 PM
vCode442's Avatar
Vincit qui se vincit
Hi scrappie - if you could post a few photos, like to to see if mine are in the right location. Thanks
Old May 29, 2020 | 02:51 AM
scrappie's Avatar
Here is a shot, maybe this helps?
Old May 29, 2020 | 05:49 AM
vCode442's Avatar
Yes it does thank you, helps me to confirm location.
Old May 29, 2020 | 09:54 AM
Thanks scrappie … huge help!
Old May 29, 2020 | 11:30 AM
vette442's Avatar
100% factory original setup. Can get you the hole locations/distance apart for the mounting screws if you need them.
Terry
Old May 29, 2020 | 02:23 PM
scrappie's Avatar
Just another shot of trunk after I replaced. Holes look to be 5" apart. No secondary holes for tabs. And pretty sure my original clips dont have tabs but I'll check next time I think about it.
Old May 29, 2020 | 04:51 PM
Thanks so much for taking the time to provide this … big help!
richeyb
Oct 10, 2025 11:27 AM
briane
May 11, 2020 08:19 PM
Doug Blake
Feb 7, 2018 05:34 PM
Rocket331
Body work
Sep 18, 2012 04:00 PM
frasco
Dec 24, 2011 06:36 AM
