Valve Cover Baffle/Breather
Old May 22, 2020 | 04:51 AM
69Chrgr's Avatar
Looking for the baffle/breather for the 400 valve cover that goes on drivers side. I think this is for the 67 but not sure.
Old May 22, 2020 | 11:26 AM
rocketscientis's Avatar
I cannot stress enough how invaluable an image of the item one is looking for is
and when the image of the item you need is posted here along with the condition required it expedites matters greatly and therefore reduces cost as well thank you that picture is very nice
Not all created equal
Horizontal top w/ louvers ?
Vac port ??
Have a varied selection of those from th 500+ engines tor down & 500+ yards visited.....so theres possability of havin a resonably priced one...but believe Jolly'0 will for shore
Omishjon4@gmail.com
67 big block
Old May 23, 2020 | 12:13 AM
Crankcase ventilator
Pulled this off a low milage 67 big block today.
is this th one you require ??
Old May 24, 2020 | 07:22 PM
Is there no one else
Is there no one else ??
must be someone in possesion of th facts of wich breather would be correct for th museum display.on 67 A/T 442...I will ask joe P if I have to...he knows I' m not that bright...only cause he shines like th sun. ..
Old May 25, 2020 | 01:35 AM
Old May 25, 2020 | 07:27 AM
69Chrgr's Avatar
Is this pic better? I need the one with louvers.
Old May 25, 2020 | 08:13 AM
lil better...4 louvers ?
& have you any idea where console wiring eminates from harness ? Harness of console has 4 pin connector two white wires in one pin one orange wire one black wire one grey wire
has a factory floor shift car that someone else car part he cannot find the wires that go to his console
Old May 25, 2020 | 08:14 AM
Old May 25, 2020 | 09:35 AM
69Chrgr's Avatar
Unfortunately I don't know much about the console. I'm only doing the engine right now.
Old May 25, 2020 | 09:36 AM
69Chrgr's Avatar
Yes the 4 louvers.
Old May 26, 2020 | 06:28 AM
69Chrgr's Avatar
No I need the one with louvers.
Old May 27, 2020 | 01:18 PM
This one has louvers
Four louvers
there you have it !
Inline
Jan 15, 2020 04:19 AM
HighwayStar 442
Sep 5, 2017 09:15 PM
Almond900
Feb 26, 2016 02:56 AM
mcutlass1969
Nov 29, 2011 05:40 AM
defiant1
Mar 23, 2011 07:50 PM
