Valve Cover Breathers
Old Nov 28, 2011 | 08:27 AM
mcutlass1969's Avatar
Checking to see what guys have done with the valve cover breathers. I still have the stock D grommits with a breather on one side and P valve on the other. In looking around i see guys have put on breathers others. Looking to change this up cheap.
Old Nov 28, 2011 | 08:33 AM
Is there something wrong with your current setup?? Are you after flashy? A few more clues please.
Old Nov 28, 2011 | 08:34 AM
Nothing fancy but getting a little oil seeping out around them. The grommits are old and i see i can buy them at Fusick's for money.
Old Nov 28, 2011 | 09:32 AM
Lady72nRob71's Avatar
Sounds like the grommets have become brittle and have shrunk with age. Replace them and you should be fine. Stock parts work great if new and engine is in decent shape.
Old Nov 28, 2011 | 10:02 AM
droptopron's Avatar
delete
I don't have the # but tehsea re still available from Help Motormite. I got one over the summer.
Old Nov 28, 2011 | 10:47 AM
Yes, HELP and airtex make repros also. I did have to modify the airtex one, as it was a bit too big in the groove...
Old Nov 28, 2011 | 12:25 PM
The round one is available at the auto parts store, I have not seen a D shaped one except thru any of the aftermarket places, yearone, opg, etc...
Old Nov 28, 2011 | 08:32 PM
70Post's Avatar
I bought the D shaped grommet just over a week ago at a local auto parts store....it was either "HELP" brand or possibly "Needa" brand. Seems like it's a pretty tight fit to get the breather in but that's probably a good thing.
I'll post the brand later when I find the receipt.
Old Nov 29, 2011 | 04:40 AM
Destructor's Avatar
Unfortunately the materials on a lot of the gromets is garbage, the oil/crankcase gasses turn them into jello. Like so many things new they won't last nearly as long as the originals.
Old Nov 29, 2011 | 05:40 AM
When inserting the filter or PCVV, put some vaseline or soapy water on the hole to make them easier to insert...
70Post
Aug 13, 2015 08:10 PM
toro455
Oct 2, 2014 10:10 PM
Vader
Sep 11, 2013 07:01 AM
66-3X2 442
Jul 13, 2011 02:09 PM
agtw31
Sep 3, 2010 11:57 AM
