1961 Dynamic 88 wheels (2) wanted
Old Mar 12, 2020 | 02:58 PM
Seattle88's Avatar
1961 Dynamic 88 wheels (2) wanted. Let me know if anybody has 2 wheels they are looking to sell. Thanks.
Old Mar 13, 2020 | 05:03 AM
Did you want steel wheels or unique wheel covers? Here's a good thread:
https://classicoldsmobile.com/forums...-wheels-91575/
You can also find 5x5" wheels on Chevy trucks:
https://67-72chevytrucks.com/vboard/...d.php?t=234769
Old Mar 13, 2020 | 07:00 AM
rocketscientis's Avatar
Or go to th sourse
Hav std oem rims
omishjon4@gmail.con
Old Mar 13, 2020 | 09:22 AM
Seattle88's Avatar
Thanks for the links, I checked them both out and it looks like all those are for 1964 and newer years. I have a 1961 and those rims were year specific from what I've been told.
Old Mar 13, 2020 | 10:02 AM
Seattle, from my understanding the bolt pattern on your 61 Dynamic 88 will be 5x5". You should be able to use any wheels with the same bolt pattern as long as the backspacing, offset and center bore diameter work on your car (might not be difficult to match center bore diameter if your car has 4 wheel drums). A problem you may run into is using OE wheel covers on 5x5" wheels from a different car. Remove one of the wheeIs from your car and do some measuring, then check your local salvage yard for any of the vehicles listed above. Here's another good thread:
https://classicoldsmobile.com/forums...pattern-23633/
Old Mar 19, 2020 | 09:21 AM
tirestarz's Avatar
Wheels
Are you looking for the 14" 5 on 5" bolt circle wheels? If so, I may be able to help you.
Old Apr 5, 2020 | 02:42 PM
newmexguy's Avatar
'63 Holiday 88 wheels available. Southern New Mexico. No bead rot. Not sure if will work for you, just throwing it out. Believe these are Fifteens. I did see a Fourteen 5 x 5 once in the yards, loose, what a strange animal.
INTRUDER
Sep 16, 2013 09:48 AM
ccnclassicoldsmobile
Jun 3, 2013 12:43 PM
INTRUDER
Oct 6, 2012 08:50 AM
michaelscheuren
Cars Wanted
Nov 21, 2011 04:04 PM
iuhoops83
Jun 1, 2010 08:02 AM
