BOP 8.2" axle to fit 65 Cutlass
Old Mar 9, 2019 | 05:18 PM
MikeManer's Avatar
I'm looking to see what's available at what cost. Thanks.
Mike
Old Mar 9, 2019 | 06:25 PM
Run to Rund's Avatar
1966 free in Vegas.
Old Mar 13, 2019 | 11:31 AM
MikeManer's Avatar
Thank you for your very generous offer. PM sent.
Old Mar 13, 2019 | 01:24 PM
RAG's Avatar
RAG
Axle
'66 is 1/2" longer than ' 65.
Old Mar 13, 2019 | 02:20 PM
MikeManer's Avatar
RAG, I thought there might be an issue with the length after doing some reading. I'm not 100% sure that this is the original rearend for this car but the axles measure 29.250".
Thank you for the information.
Mike
Old Mar 13, 2019 | 04:13 PM
jcdynamic88's Avatar
just to be clear,the 66 assembly is a direct bolt in but is longer outside the mounting points.if you are not running real fat tires or deep rims it's not a problem.the 67 -72 will fit also but spring mounts are different.jc
Old Mar 14, 2019 | 05:23 AM
ROCKETMAN269V's Avatar
We put a '68 3.91 posi under my '65 Cutlass, without any issues with the spring mounts. I'm not sure what you're referring to.
Old Mar 14, 2019 | 09:36 AM
the 66 and earlier rear coils are bolted to a pad on the housing,so you need the style springs that go with the housing.the bottom of the 65 coil doesn't fit over the later perch.
Old Mar 14, 2019 | 05:18 PM
stan 65 cutlass's Avatar
yes the 66 up is wider than 65
Old Mar 14, 2019 | 08:09 PM
lemoldsnut's Avatar
You did not say unless I missed it what ratio you are looking for? You said axle are you looking for a full rear end or just an axle shaft?
I have a few 65's 66's and 67 rear ends.
Larry
lemoldsnut@aol.com is the best way to reach me.
Old Mar 15, 2019 | 07:18 AM
MikeManer's Avatar
Larry, I'm looking for an axle shaft. Thanks for the reply.
Mike
Old Mar 16, 2019 | 03:20 AM
lemoldsnut's Avatar
I am pretty sure I have a rear end I can get you an axle shaft from. Be sometime later the coming week when I can get to it.
Email me direct at lemoldsnut@aol.com
or call west coast times 541-815-4363
Should be able to get to it on Thursday or Friday
Larry
Napoleon1991
Cars Wanted
Oct 4, 2016 05:46 PM
starr88
Oct 18, 2015 08:02 PM
Bfg
Jun 20, 2015 03:05 PM
Rickman48
Oct 4, 2012 05:31 PM
oldshunter
Aug 30, 2007 12:59 AM
