Looking for ‘66 starfire parts
Old Jan 8, 2018 | 12:00 PM
Olds92's Avatar
Hello,
I am looking for some parts. Pretty sure 88’s are interchangeable but not sure on that. Here’s what im looking for. Please reach out if you have these.
Fuel tank
fuel tank sending unit
exhaust (don’t need manifolds)
body mounts
Also, is there such thing as disc brakes ??
Thank you all.
Old Jan 8, 2018 | 12:35 PM
The 1967-70 full size Olds disks will fit back to 1965. I believe there is at least one set for sale on this site (Scott? John?). Be aware that no one makes replacement rotors, however it is possible to adapt the rotors from a 2010 Camaro V6 with some machine work. Use the 1969-1970 setup with the sliding single piston caliper.
Old Jan 8, 2018 | 01:02 PM
m371961's Avatar
Joe, does that require a switch to 15 inch rims? (the 67-70)
Old Jan 8, 2018 | 01:03 PM
Yes, since these are 12" rotors.
Old Jan 8, 2018 | 01:33 PM
2blu442's Avatar
Yes, I still have a setup for sale but I'm in Oregon, Scott is in Indiana. I believe Scott has sold his, but he's come up with two sets within the last year. If your not in a hurry you could let him know your looking and if he comes up with another set you could be first in line.
Here's a link to my ad
https://classicoldsmobile.com/forums...hangeover.html
Joe, I need to create another thread discussing these brakes. I've got the rotors and 4 piston calipers from a 1967, then the complete setup with single pistons from the 1970. The rotors look to be the same, although I can't find numbers in the 1967's. I need to take some good measurements and photos but its possible the 67-70 used the same rotors even though the calipers changed from 4 to single piston designs. John
Old Jan 8, 2018 | 01:36 PM
Yeah, I bough one set. I didn't realize the other had sold.
Old Jan 8, 2018 | 01:43 PM
2blu442's Avatar
Scott is in a good location for shipping parts. I had someone interested in mine, but shipping made it too expensive. He was able to buy Scotts and make it worthwhile. Eventually I'll find someone on the West Coast interested in these.
Old Jan 8, 2018 | 03:01 PM
65B01Delta's Avatar
PM Sent
Old Jan 8, 2018 | 05:17 PM
Olds92's Avatar
Would I still be able to use the factory speedo cable? Thanks guys good info
Old Jan 8, 2018 | 06:15 PM
Yes
Old Jan 9, 2018 | 02:10 PM
cfair's Avatar
Just to add to the 65-70 disc brake conversion theme, my ‘66 98 with ‘70 rotors is using ‘71 98 calipers. They just needed a bit of filing on the mounts to fit the 70 backing plate. No negative effect on function for 15 or 20 years now.
I kept the big 66 2.5” rear drums factory. Which may bite me some day since those drums have got to be rare now.
Old Jan 9, 2018 | 06:16 PM
Charlie Jones's Avatar
Phantom Phixer
Hello,
I am looking for some parts. Here’s what im looking for.
body mounts
The six large body mounts (four below the firewall and two above the rear axle ) in a 63 thru 66 big car are the same as 66 Toronado .
Steele Rubber repo's these.
The smaller round mounts , and the square ones might be available from Ames Performance Engineering . A Pontiac supplier.
They show all the dimensions of their available mounts in their full-size car catalog .
I found all the mounts for my '63 Dynamic 88 this way .
Old Jan 9, 2018 | 07:15 PM
cfair's Avatar
Body mounts
By any chance do you have part numbers for future reference?
For any / all you’ve found successful on your car.
Cf
Old Jan 9, 2018 | 10:18 PM
Phantom Phixer
Cf
The big mounts are by Steele Rubber and are #70-2283-48
https://www.steelerubber.com/body-mo...pad-70-2283-48
The other mounts were selected from the Ames catalog on page 262 .
They were four PS 413 (square) and two PS 416 (round ) mounts .
These were not exactly the same in all dimensions as the originals . But they are "close enough ".
These were for a '63 . Your '66 is different , so you will have to measure and "pick and choose " .
Here's a link . See page 262
http://www.amesperf.com/catalogs/P20.pdf
Old Jan 9, 2018 | 10:23 PM
Phantom Phixer
I discovered that the Toronado body mounts fit all (full-size) 63 thru 66 , while snooping around the 1972 Oldsmobile Master Parts Catalog . Same part number .
Old Jan 12, 2018 | 01:04 PM
Olds92's Avatar
Charlie Jones thank you SO much for the information and researching extra for me. Appreciate it.
Old Jan 12, 2018 | 02:29 PM
Phantom Phixer
Glad to do it !
When you own one of the " big girls " you have to do a lot of research to find parts .
For $25 you can join the Automotive History Preservation Society , and they have a 1972 Oldsmobile Master Parts Catalog online ( covers back to '63 or so ) . (members only)
http://wildaboutcarsonline.com/cgi-b...0262549471.cgi
Old Jan 12, 2018 | 02:34 PM
jhoppeolds's Avatar
I can probably come up with a complete '69/'70-style disc brake setup. Spindles, dust shields, rotors, calipers, master, booster, prop valve, etc. I'm on the south side of Milwaukee, so not that far away (depending, though, on exactly where in Illinois you are). $300 for everything. Some parts would probably have to be rebuilt due to age.
1962oldsguy
May 19, 2019 08:08 PM
electra483
Aug 9, 2015 05:13 PM
Oldssupreme
Feb 3, 2013 06:26 AM
Oldssupreme
Feb 3, 2013 06:24 AM
starfiredownunder
Dec 18, 2012 06:07 PM
