Need one pair of NOS spiral rear shocks for a 70-442
Old Jul 16, 2017 | 03:06 PM
capstoneclub's Avatar
Cannot be longer than 20 1/2 inches fully extended (repops are longer). Pls send PM if you have correct shocks.
thanks-
Old Jul 17, 2017 | 07:28 AM
ROCKET VAPOR's Avatar
Lance
Originally Posted by capstoneclub
Cannot be longer than 21 inches fully extended (repops are longer). Pls send PM if you have correct shocks.
thanks-
CAPSTONECLUB,
The current available repro spiral shocks will not work correctly on a stock ride height '70 442?
Old Jul 17, 2017 | 09:28 AM
mrolds69's Avatar
I'm guessing he wants that specific extended length because many shocks sold now are longer. If you jack the car up with the factory bumper jack, it won't go high enough to pull the wheels off the ground, or it will be extended to a point where it's unsafe. I realize most car guys here would never use their bumper jack. It's still nice to know it would work, though. I don't know the extended length of the current repro spirals. Maybe he has bigger tires, or higher springs.
Old Jul 18, 2017 | 07:39 AM
Funkwagon455's Avatar
Maybe check with this fella.....
https://dallas.craigslist.org/sdf/pt...219113991.html
Old Jul 18, 2017 | 12:41 PM
AzChevs's Avatar
If you don't find NOS,I have a pair of used ones, car was from Tucson originally and sat in the desert for over 25 years. Pit free, still tight, 250.00 pair plus shipping. Here is a link to my current Ebay listing for them with photos. http://www.ebay.com/itm/100-Point-Ca...-/282569624709
Old Jul 20, 2017 | 03:48 PM
No, the repops are 21 1/2 inches fully extended
When you put a 70-442 on a lift (assuming the springs are stock/original length), the springs do not even make contact on the top side when using repop shocks. Prior to dropping the car back down, you need to always double check to see that the springs are in the correct position. Since the repops are one inch longer than stock, you might notice a shift of the intended correct position of the spring itself. Not a huge deal, just not as originally intended by design and a bit of a nuisance.
Old Jul 20, 2017 | 09:18 PM
stevengerard's Avatar
those sure are nice looking and I do like the way you market them for the 100 point folks — good idea
Old Jul 21, 2017 | 07:30 AM
Lance
When you put a 70-442 on a lift (assuming the springs are stock/original length), the springs do not even make contact on the top side when using repop shocks. Prior to dropping the car back down, you need to always double check to see that the springs are in the correct position. Since the repops are one inch longer than stock, you might notice a shift of the intended correct position of the spring itself. Not a huge deal, just not as originally intended by design.
Thank you for the information, as I was looking into getting a reproduction set for all four corners.
Old Jul 21, 2017 | 09:47 PM
AzChevs's Avatar
Thank you
rcktdoc
Feb 29, 2016 04:20 AM
oldspackrat
Mar 7, 2015 03:52 PM
Pacecar
May 17, 2012 08:47 AM
charlierogers
May 17, 2012 02:12 AM
lionelbob
Nov 12, 2009 06:42 AM
