1969 Hurst Olds Engine Parts
Old Jul 2, 2017 | 12:10 AM
WhiteRockH/O's Avatar
Hello:
Just purchased a 69 Hurst Olds (#466) and the immediate goal is to try and get the engine compartment looking like a 69 H/O should. Under the hood, there are lots of little things (and a few big things) that need attention.
The two biggest and most difficult needs we have, is to find a suitable repo 69 H/O Intake Manifold and an Air Cleaner "Top Hat". Our H/O is not a numbers matching show car, so we don't need one of the ultra rare original intake, just one that looks and operates correctly when mated to the proper air cleaner assembly. With respect to the "Top Hat", a repo would also be fine (we would prefer metal over fiberglass if at all possible), and if we could find a real poor but restorable condition original metal "Top Hat", that would be our first choice. Currently the car has an original 1970 W30 Ram Air Cleaner on it, so if someone needs one of those, it will be available once we receive the car (7 to 10 days from now).
Thanks in advance for any help or leads for these two parts.
Very best regards,
Michael
Old Jul 2, 2017 | 06:29 AM
edzolz's Avatar
Please post your location. It might make a difference in your being able to get parts shipped to you.
Old Jul 2, 2017 | 07:31 AM
ROCKETMAN269V's Avatar
Originally Posted by WhiteRockH/O
......is to find a suitable repo 69 H/O Intake Manifold......we don't need one of the ultra rare original intake, just one that looks and operates correctly.......
I have a 404521 "L" cast iron intake. This is for the '70 455, and has the same provision for the pcv valve in front of the carburetor. The hole is not machined; but is spot faced and easily opened up. Email me if interested: drolds1@bellsouth.net. Thanks, Bob.
Old Jul 2, 2017 | 08:46 AM
70-442-W30's Avatar
344879M363895
Hello:
Very best regards,
Michael
Does it have the original chrome valve covers? I can possibly help you out with that if needed.
Old Jul 2, 2017 | 08:54 AM
Hi Edzolz:
If the shipment is coming from the USA, the delivery address would be in Blaine WA 98230.
Michael
Old Jul 2, 2017 | 09:05 AM
Hi Rocketman269V:
Thanks for the reply. Our first choice is to find one we can just bolt on and not do any extra machining, but because they are difficult to find, this maybe the only option. I will give it a couple of weeks to see if anything else shows up and then get back to you about it.
Sincerely,
Michael
Old Jul 2, 2017 | 09:11 AM
Hi 70-442-W30:
Thanks for your reply. I am pretty sure that the chrome valve covers on the car are not original 69 H/O ones, so yes I would be interested in the set you have if you are willing to let them go to be used in a real H/O car. I will send you a Private Message so we can talk about it further.
Very best regards,
Michael
Old Jul 2, 2017 | 09:27 AM
Hi Rocketman269V:
......Our first choice is to find one we can just bolt on and not do any extra machining.......
I have access to an excellent machine shop. Sadly, there was a member here that use to modify these to "appear" correct. He purchased a couple from me over the years. The only other concern is the actual fitting that presses into the opening, once it is machined. I believe that there is a detailed explanation of how to do this in an old thread. For outward appearance, a piece of steel tubing, with a brass ferrule on it is supposed to work just fine. Just something else to consider.
Old Jul 2, 2017 | 09:45 AM
Hi Rocketman269V:
Thanks for the tip...I will try to find the thread and learn more about it. Question, does the 1970 442 iron intake for a manual transmission car already have the PVC nipple in it (407568)? ...and if so, what would be the other differences between the 407568 and the one you have available (404521)? Thank you for taking the time to educated me about it.
Sincerely,
Michael
Old Jul 2, 2017 | 10:25 AM
geardoc66's Avatar
While the 1970 intake has provisions for the PCV, it also uses a completely different choke. The '68-69 intake uses a divorced choke with the spring that sits in a pocket on the heat crossover. The '70 and up intakes use an integral choke with the hot air tube that bolts to the exhaust crossover. If you have any desire to use an original carburetor, the choke system will not adapt to the '70 intake
Old Jul 2, 2017 | 11:06 AM
Red face
Thanks for noting that. I wasn't even thinking about the choke set-up. I guess that the ones that Chris modified were the 398662. Sorry for the confusion.
Old Jul 2, 2017 | 11:08 AM
442crzy's Avatar
PM sent
Old Jul 2, 2017 | 12:37 PM
70-442-W30's Avatar
344879M363895
Hi 70-442-W30:
Very best regards,
Michael
Great, I'll set them aside reserved for you until I hear otherwise.
Old Jul 2, 2017 | 02:37 PM
Thanks Geardoc66:
Really appreciate the valuable information. The right one will come along eventually. Really looking forward to getting out and enjoying the car.
Best regards,
Michael
Old Aug 12, 2017 | 08:01 PM
classicmuscle442's Avatar
Just got a J intake with some blocks, it is a 309662. If still needed let me know, shipping would be from 48843.
Old Aug 13, 2017 | 02:02 AM
Bob Anderson in Tampa Fla repos very nice metal top hats but they are expensive
Check cars for sale in Juno and he usually has a few with his phone number. He's not an internet user as far as I know
I have a set of chrome valve cover but have no idea if they are original [nor can I find out how to tell the diff]
Old Aug 14, 2017 | 04:42 PM
442crzy's Avatar
PM sent
70-Olds-442-convt
Sep 17, 2018 12:12 PM
Ctls442
May 1, 2016 12:05 PM
Jul 26, 2015 03:02 PM
camshaw
Aug 13, 2013 06:21 AM
wizarddrummer
Oct 1, 2011 10:38 AM
